Who would REALLY pay for Targa?
nope, haven't had it done yet. no one ever showed enough interest to have the shop do the research on my car. It still may be done at some time...but I have other things to do first...like forced induction etc. the body kit all came together...and the supercharger went on this last weekend. hopefully soon the targa will happen too...
and yeah, this thread is WAY old!!
there really isn't a "chassis" to stiffen up, Z's are unibody cars. the convertibles have different sheetmetal stamped floors from the factory. i wouldn't do it. i'm sure the shop that will take on the job doesn't have a chassis stiffness test facility like nissan has.
maybe take a convertible and make it a targa?
just my opinion.
just my opinion.
just my opinion.
just my opinion.
There is never going to be a way to have a targa down in a "group buy"-type situation like you are/were suggesting OP. Or at least not in a way that people would climb on board with a particular shop if they aren't halfway nearby--especially without someone taking the plunge and being the guinea pig first.
This topic has been discussed for years and I have only seen one Z actually go through with it (the one that 05Z33 posted). That doesn't mean it can't be done by any means, just that every single person that says "I'M DOIN IT!!1!1one!" never follows through.
For what it's worth, there has been a guy on 3SI that put a targa on his 3KGT...he's had to do quite a bit of work to make it structurally sound, but it looks rather fantastic.
A synopsis of what he did structurally:
Someone other than that ugly showcar will get this done eventually, just a matter of someone willing to chop up their Z.
Personally I would love to see someone just do the center section and leave the door frames (like the newer 911 targas); this seems like it would not hurt rigidity as much as cutting the entire roof off, and would not have NEARLY as many problems getting the top to fit back on because the fastening system would be a lift-out/drop-in.
Reinforcement:
All pillars were reinforced with cold-rolled steel plate. The interior of the floorpan had 4 inch steel c-channel welded in parallel to the length of the car and steel plate was welded laterally at the front and rear of the floorpan. Beneath the car, two trapezoidal frames made of square steel tubing were welded on either side of the exhaust/driveshaft channel and tied together with steel plate used as tension straps. This prevents flex sideways and front-to-back with the roof removed. The rear roof section had a custom piece welded in to it to reinforce and provide the roof with an attachment point.
Looks like an NSX
Originally Posted by turismo
Looks like an NSX
It REALLY looks like an NSX. My friend has pictures of it when the owner showed up at one of the 3SI Gatherings, at first glance from the rear it really resembles that.
Originally Posted by Mr Pickles
I hope to see the Targa around town if/when you decide to go through with it
it's a ways out if it happens...still trying to get some performance in place. Then more looks...you might have seen my Z around already tho.
You have one? what color? where in the fort are you??
My body shop said they wouldn't do it because the roof provides alot of the bridging support between the front and back..and the rear and sidewall bracing that would have to happen to compensate for the lack of rigidity it would almost be like a mini-cage setup. plus I'd want the ability to remove the top in 2 peices so it fits in the back....Alot of work and $$$.
I'm northwest area, a mile or so away from Northside High school if you're familiar with that area. I've seen one Daytona Blue one around before, but lately the ones I happen to see (which isn't too often) have been Silver.
And nope not yet. Planning on getting one within the year. Not sure if I'll end up doing it tho depending on how it handles during winter. I may wait till next spring. Is the Z a realistic Fort Wayne winter car? I've seen people say yes and no for the winter months.
Mine is lowered with a body kit...and I drive it in the winter...but do have issues on days w/ deep snow. When it wasn't lowered and body kit....i never had a day I couldn't get around on...but...i've been driving rear wheel drive cars for years...in the snow. So it depends on your comfort level.
I think there are 2 (at least) DB in town...mine, which doesn't look stock at all...and then one other that is bone stock.
oh alright, cool. Maybe I'll pick one up later this year then. I saw a DB back in 03 I think it was, and it was stock (except rims). And didn't see another in town for a few years, but that one was also stock so I don't think I've seen yours around.
