nismo gauge cluster
Old Dec 12, 2006 | 08:01 AM
st350z's Avatar
st350z
Default nismo gauge cluster
I just got this thing, any one know a thread or have instructions to take the stock one off?
Old Dec 12, 2006 | 08:08 AM
nothingremains's Avatar
nothingremains
so just the nismo logo makes it different huh..
Old Dec 12, 2006 | 08:11 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
sorry man, that wont work with a usdm car. You better it sell it to me, cheap, and at a huge loss!
j/k
Ive posted the ins before, its really easy.
Step 1, disconnect battery
step 2: theres two screws holding the lower steering column cover on. Youll need a long phillips head to remove
step 3: remove key ring hole, may need to be done before 2
step 4: lower the lower steering column cover and unclip the wire thing attached to it
step 5: 4 10mm bolts hold the cluster on, remove those and your set
install in reverse.
MrKaira's Avatar
MrKaira
Really MrZ31
it's in km/h; no redline on the tach (unless you can't see it); gas gauge is different. Its just for the sake of being different... not something I would pay retail for but if it was a good deal then its cool.
sorry bud don't have any idea of how to take the stock off
Old Dec 12, 2006 | 08:12 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
how about the no redline, and in kmh? and its nismo, +5hp
Old Dec 12, 2006 | 08:13 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
^ if you look closely it is in Kilometers not MPH
Old Dec 12, 2006 | 08:14 AM
savvy's Avatar
savvy
oh man having the kmh istead of the mph would **** me off so bad
Old Dec 12, 2006 | 08:15 AM
IIQuickSilverII's Avatar
IIQuickSilverII
anybody knows if a 2003 base gauge clusted woudl fit in a 2003 enthuziast gauge cluster and work fine?
do the miles get adjusted with "whats on the ecu"
*edit* sorry for the thread hijack
Old Dec 12, 2006 | 08:23 AM
st350z's Avatar
st350z
I'm going to install this tonight. thanks for the instructions CUxtopher.
I use the digital mph in the center anyways so the km/h well not matter as long everything else works.
Old Dec 12, 2006 | 08:56 AM
TurboSteve's Avatar
TurboSteve
do not risk it, or cheapen your car with an inaccurate gauge cluster... sell it to someone who can actually use it
my .02
Old Dec 12, 2006 | 11:23 AM
davidf's Avatar
davidf
Even the gas gauge is different.
Old Dec 12, 2006 | 12:44 PM
240Zplus110's Avatar
240Zplus110
I thought the genuine Nismo cluster has a white background? IIRC the cluster for the G35 is this way.
That could be just a normal cluster for Canadian/European markets with a Nismo sticker on it.
Old Dec 12, 2006 | 09:27 PM
st350z's Avatar
st350z
http://www.japanparts.com/NissanPart...46-003-006.jpg
Old Dec 12, 2006 | 09:36 PM
st350z's Avatar
st350z
every thing works even makes the mph in the center console read km/h
Old Dec 12, 2006 | 09:47 PM
Changvi's Avatar
Changvi
Nice!!
Old Dec 13, 2006 | 03:09 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its real...the JDM NISMO cluster for a Z does not come in white, just as pictured above
Old Dec 13, 2006 | 03:55 AM
gringott's Avatar
gringott
Note: Higher speed range.
Z350Lover's Avatar
Z350Lover
yup... adam is correct... because I have got one in my car too... and I can tell that you got it second hand because your milage didn't start from "0"...
Looking good too... and also... there is no cruise control lights in that cluster
cheers,
richie
Old Dec 13, 2006 | 05:31 AM
gringott's Avatar
gringott
Hmmm. I didn't know it changed the center console output. Guess I'll stop looking for one at a good price.
Old Dec 13, 2006 | 05:51 AM
Z1 Performance
Former Sponsor
you can see from the cluster it also reads in MPH (the small #'s under the KPH (larger) #'s
I don't see how it would alter the center console output - the plug for the console is seperate from the speed cluster plug, they do not plug into one another (at least not on my Enthusiast car...not sure about higher trim models
