Drift E-Brake Knob!?
Old Dec 22, 2006 | 04:27 PM
ZZ33bOI's Avatar
ZZ33bOI
Default Drift E-Brake ****!?
Just curious who uses these *****? Im tryin to find one that works for my Z any suggestions?
Old Dec 22, 2006 | 04:32 PM
Chebosto's Avatar
Chebosto
are you talkin about rear ebrake conversion to hydralic pump rather than cable?
Old Dec 22, 2006 | 04:35 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
i think hes talkin about those little things that hold the button in so that it doesnt lock and you can just pull it w/out hitting the button. Although youd be screwed if you had to park on a hill. Unless you just leave it in gear but taht would be kinda hurting the tranny
Old Dec 22, 2006 | 04:38 PM
ZZ33bOI's Avatar
ZZ33bOI
+1!!!! any suggestion on which one to get? i dont live in the hills so it shouldnt be a problem..and even if i do park it in the hill ill leave the e-brake up and in 3rd gear...
Old Dec 22, 2006 | 05:23 PM
Chebosto's Avatar
Chebosto
its called some gorilla glue tape and a wooden dowel from home depot. to make it accessible..
Old Dec 22, 2006 | 05:28 PM
stan's Avatar
stan
someone should make a little beer cozy type thing that slips over the ebrake handle and fits tight enough that you can slide it down and have it hold the button in. ergonomics + function.
actually, scratch that. steal my idea and your *** is grass. $30 shipped!
Old Dec 22, 2006 | 05:33 PM
DaveZ06's Avatar
DaveZ06
thats sound like a good idea sicne i'm kinda lazy and pushing a button is like running across the states for me... but it sounds like a major safety issue
Old Dec 22, 2006 | 05:40 PM
ZZ33bOI's Avatar
ZZ33bOI
What do you guys think about this lil gizmo?
http://www.driftingperformance.com/c...7fde313ecb7053
Old Dec 22, 2006 | 05:52 PM
DaveZ06's Avatar
DaveZ06
^^ the red **** is sexi... wonder if they are a nice tight fit.
Old Dec 23, 2006 | 02:13 PM
streetd's Avatar
streetd
I have one on my car, kinda pointless cause the ebrake isnt real strong, but cool none the less. I bought it from driftfactory.com. Here is the link http://www.driftfactory.com/product_...products_id=59
All I did was take the spring out of the ebrake handle, replace it with some mechanics wire so it connects the same spots as the spring. Then I took the stock button off and shaved it down with a dremel until it fit inside the drift **** nice and tight. And thats it. It releases just like the stock button, but since there is no more spring you have to hold the button out when you lift the ebrake. Not hard at all.
Old Dec 23, 2006 | 10:25 PM
supra crazy's Avatar
supra crazy
Noice
Old Dec 24, 2006 | 01:50 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I have something like this on my old Mini, you can yank up the handle but it only locks in place when you push the button in. Then to release it you yank it up again and it releases.
Looks like this
You would think someone would make these for Zs (and other drift worthy cars) if I can get one for an old Mini.
Chris
Old Dec 24, 2006 | 04:18 PM
driftk1d's Avatar
driftk1d
my e-brake sucks so this wouldnt help me...do any of you know how i can make my e-brake stronger? cool product nonetheless
Old Dec 24, 2006 | 05:02 PM
ZZ33bOI's Avatar
ZZ33bOI
Nice!! thanks a lot on the imput!!! im thinkin one for my christmas present for my baby!!! anymore suggestions?
Old Dec 24, 2006 | 05:32 PM
davidf's Avatar
davidf
I hope you guys realize how small the park brake shoes are when your tossin it sideways with the e-brake. Buy spares.
Old Dec 24, 2006 | 05:38 PM
willyd6869's Avatar
willyd6869
Just to clarify things: "Spin turn *****" or "drift *****" do not disable the locking mechanism on the e-brake...to lock the e-brake in an up position with one, you just pull the **** outwards
Old Dec 25, 2006 | 02:27 PM
ZZ33bOI's Avatar
ZZ33bOI
What? explain....
Old Dec 25, 2006 | 03:18 PM
supergodzilla's Avatar
supergodzilla
the drift button just basically removes the spring mechanism from the ebrake.
in order to park when you pull the ebrake up you just pull the drift button outwards.
Old Dec 26, 2006 | 02:14 PM
streetd's Avatar
streetd
I just put my finger in the gap its leaves between the end of the **** and the handle when I pull the brake up, it locks very easily.I barely have to pull on the ****. I don't use it to try to drift because the ebrake really does just suck. Its just kinda cool.
Old Dec 26, 2006 | 02:41 PM
charged's Avatar
charged
I just installed a Momo E BRAKE handle and boot. When you put in kit, you can take out spring. It will look a 1000x better and be functional for your needs.
