Tail Light Question .... brake lights work not running lights...
Old Jan 29, 2007 | 07:55 AM
ocZ's Avatar
ocZ
Default Tail Light Question .... brake lights work not running lights...
The problem I have here is when i turn on my headlights, my tail lights don't
light up.
When i apply pressure to make brakes, they light up along with my led 3rd brake light.
I'm sure it could be a simple fix and a fellow member has had a like problem.
Anyone wana shoot me in the right direction?
Thank you.
Old Jan 29, 2007 | 08:07 AM
padam07's Avatar
padam07
Have you checked your fuses?
Old Jan 29, 2007 | 08:40 AM
ocZ's Avatar
ocZ
Not yet...is there a specific one I should look for?
Thank you.
Old Jan 29, 2007 | 12:58 PM
HighwaySpeed's Avatar
HighwaySpeed
Call dealer
Old Jan 30, 2007 | 09:56 PM
frenzee's Avatar
frenzee
The tail light fuse is in the fuse box behind the battery (not the one on top right next to the battery but the one hehind it). It's a b*** to get at becasue you have to remove the battery and (crefully) remove the black plastic panel under the wiper. Be careful when you put that panel back on becuse if you bend the part that fits into the adjacent panel, you won't get a good seal with the windshield and water will leak into areas that you don't want. I don't think the fuse is clearly marked as "taillight". I had it go out once and I had to remove every fuse to find it (and of course it was the very last one I tried, LOL, oh well). There is a thread here that talks about this with a diagram. Before you delve into this, make sure that the bulb isn't blown and that it is well seated.
Miguel Albanez
Oct 17, 2022 10:13 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Vigman
Nov 17, 2015 04:34 AM
Ronso
Oct 30, 2015 12:39 PM
Shane86
Sep 17, 2015 05:33 PM
