Help: Window Tinting!
Old Apr 6, 2003 | 12:35 PM
fotodad's Avatar
fotodad
Default Help: Window Tinting!
I'm thinking of having my passenger and driver side windows on the Z tinted by an area automotive window tinting place. They come highly recommended and seem to know what they're talking about, but I've never had windows tinted before. What should I beware of when looking to have my windows tinted?
Are there certain tinting processes that are better than others?
Are there certain tinting products that are better than others?
Anything else I should know before going ahead with tinting the windows?
Thank you! I appreciate and value all comments.
Michael
Old Apr 6, 2003 | 02:06 PM
speedracerxx1's Avatar
speedracerxx1
they all use a water and soap type additive so the tint will move around the window when applying the tint so they can match it up to the window once is is cut, then they squegee the tint on the window normal practice type stuff. oh and the lower the the percent number is darker 50% light 5% dark they sometimes call it limo tint 5%. also have 35% 38% 20% bronze, smoke, silver to smoke fade.
Old Apr 9, 2003 | 11:08 AM
MSGarrett1's Avatar
MSGarrett1
Also, not all tints are the same . . . some block more heat in the infrared spectrum than others. One manufacturer called Huperoptik (www.huperoptik.com) makes a relatively expensive ceramic-based tint that blocks 99% of the HEAT. So you can have the tint as dark as you like for looks, but still have the interior cool even on the hottest of summer days. Also, cheaper, dyed tints are prone to fade more with time, turning a purple-ish color. This only means you have to re-tint the windows in 5 years or so.
Old Apr 9, 2003 | 01:53 PM
GY-Z's Avatar
GY-Z
i want to tint my window too, but i am just wondering if the function that the window will goes down a little bite when the door open will distruct the process of tinting?
or can the function be dismissed?
Old Apr 9, 2003 | 03:18 PM
alphared's Avatar
alphared
theres a switch on the door jab, just push it and window should come back up
Old Apr 9, 2003 | 03:52 PM
GY-Z's Avatar
GY-Z
door job?
can u explain more clearly?
which side of the door does the "door job" locate at?
and wat does it looks like?
thanx~!!
Old Apr 9, 2003 | 10:53 PM
TheLex's Avatar
TheLex
What about REMOVING the tint? How hard is that, and will it damage the rear window heating elements?
Old Apr 10, 2003 | 08:44 PM
GY-Z's Avatar
GY-Z
i know wat ur saying now ...
but..how can i kept the jab being pushed inorder to not have the window goes down automatically?
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
