E-Brake Adjustment
on
so my guess if i take off rear tire.....i should see something that would look like a bolt to tighten right?
thanks guys
keep em coming....i need as much info as possible
thanks guys
on
thanks guys
thanks guys
No there's a grommet in the rear disc, you have to get it to the top and adjust the knurled wheel inside. It adjusts up and down, from memory, down tensions the e brake...adjust it so the disc stops moving, then take it back until the disc just about spins freely.........one side done! If you're not confident, please get your dealer to do it!
Here's the section from the manual....
on
xirtam
10-03-2015 02:06 PM
