How to disable "Low Wiper Fluid" indicator
Old Mar 10, 2007 | 05:47 AM
amacahilig's Avatar
amacahilig
Default How to disable "Low Wiper Fluid" indicator
For all the weight saving gurus, i just emptied my windsheild wiper fluid to get rid of dead weight. But now there is a low wiper fluid indicator showing. How can this indicator be turned off?
Old Mar 10, 2007 | 09:13 AM
sofa king's Avatar
sofa king
wow! did you save like a pound or 2? skip a meal, itll prolly do the same. are you doing some sort of time attack? whats the point of this?
- maybe im just not that hardcore.
Old Mar 10, 2007 | 10:06 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Yep ^^^... if u saved more than a pound or 2.. ill be suprised...
Old Mar 10, 2007 | 10:13 AM
plumpzz's Avatar
plumpzz
It uses a full gallon and ahalf which is probably around 10 lbs. Also, its in the very front of the car, reducing interial load on the car!
Old Mar 10, 2007 | 11:48 AM
sofa king's Avatar
sofa king
1 gallon = about/maybe 5lbs.
i can understand the concept..but it just doesnt seem worth it. get a CF hood.
Old Mar 10, 2007 | 12:16 PM
Cannysage's Avatar
Cannysage
you gotta be kidding.. that's hardcore
Old Mar 10, 2007 | 12:18 PM
VN_350z's Avatar
VN_350z
take out the fuse for winshield wiper.
Old Mar 10, 2007 | 12:24 PM
diwun67's Avatar
diwun67
Unplug the harness from the washer bottle maybe?
Old Mar 10, 2007 | 12:27 PM
saberphx's Avatar
saberphx
Don't knock on this guy for trying to balance the front heavy Z! The windshield wiper bottle is in the very front of the car where every pound counts! And no as authentic dry carbon hood isn't going to save you much weight at all (though every pound counts!), the stock hood is aluminum.
Old Mar 10, 2007 | 12:35 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
1 gallon of water is 8.4 lbs, its safe to assume that windshield washer fluid has the same densiy as water. 1.5 gallons is nearly 13 lbs of the front right wheel! not a bad weight savings. Shave the rear wiper ,motor, tubing and youve got another 2 lbs or so.
Old Mar 10, 2007 | 12:49 PM
InZomniac's Avatar
InZomniac
What he /\ said. I have removed a few for various people. It saves about 12 pounds in front of the wheel centerline. About 4 times better than a CF hood.
Old Mar 10, 2007 | 02:47 PM
amacahilig's Avatar
amacahilig
you lose around 13 lbs. where it counts. so just unplug the wiper harness?
Old Mar 10, 2007 | 03:02 PM
2005daytonaZ's Avatar
2005daytonaZ
I'm thinking the rear wiper weighs a little more than just 2 pounds....But i could be wrong...been a while since I took mine off.
Old Mar 10, 2007 | 03:39 PM
diwun67's Avatar
diwun67
you loose around 13 lbs. where it counts. so just unplug the wiper harness?
The harness plugged into the bottle
Old Mar 11, 2007 | 01:57 PM
Rick06Z's Avatar
Rick06Z
Old Mar 11, 2007 | 09:45 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Black tape over the indicator? LMAO
Ok sorry, back to the real replies!
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
