Antenna Mount
Old Mar 14, 2007 | 10:31 AM
BiGGD198's Avatar
BiGGD198
Default Antenna Mount
ok so my antenna broke on me and i need the new piece that the antenna screws into because the male part of the antenna is stuck in there. i took eveyrthing out and went to the dealer and they said it would have to be ordered and will run me $215 .....i said PAAAACE!! and walked out I was wondering if anyone knew where i can get the stock one for ALOT cheaper or any aftermarket that will work? Thanks.
Dan
Old Mar 14, 2007 | 10:43 AM
phatz33's Avatar
phatz33
I'll sell you my factory antenna for $10
Old Mar 14, 2007 | 11:03 AM
35TH ANY's Avatar
35TH ANY
Can't you get it out with an EZ Out?
Old Mar 14, 2007 | 11:07 AM
blaukal's Avatar
blaukal
+1. you should be able to drill it out no problem. save some money.
Old Mar 14, 2007 | 11:09 AM
Jay'Z's Avatar
Jay'Z
Try wd40 too.......
Old Mar 14, 2007 | 11:11 AM
Muzlimchu's Avatar
Muzlimchu
You break things like that all the time. EZ-out like said above or there are various other ways. How did it break? Was it siezed in the hole or just snapped it of grabbing it wrong?
Is it all the way in, or can you cut a slot in the top and use a flat head? or grap it with vice grips.
Old Mar 14, 2007 | 11:43 AM
BiGGD198's Avatar
BiGGD198
it was seized and broke at the carwash...the only thing is i didnt notice it while leaving, i noticed couple hrs later...so i really cant proove it. i will try EZ out and hopefully it works....if not ill try the screw driver...thanks guys. if none of those work.....any idea's on where to purchase them ALOT cheaper than "stealerships"?
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
