Auto Meter Nexus Firmware For Nexus Wideband
Old Mar 23, 2007 | 09:56 AM
Kenk2's Avatar
Kenk2
Professional
Default Auto Meter Nexus Firmware For Nexus Wideband
Well I posted this firmware update in the FI Section but figured I would start a new thread strictly dedicated for searching purposes..
This update is required if you buy the New Nexus Wideband A/F gauge. Please follow all directions and/ also, I am not responsible for bad flashes
File can be downloaded HERE < Right Click Save Target As Please..
Here is some extra info..
This firmware will be revision 4 and will flash the record light 4 times on start up.
To load this onto the remote, you need to:
1) save the FW0118_1.rff file to an SD card
2) with power OFF, insert the SD card into the remote
3) hold down the record button
4) turn power ON to the Nexus system
5) the record light will be solid green while the firmware is being loaded
After loading new remote firmware (FW0118_1.rff ) the open, close and demo files will be erased.
These files are also attached and will have to be reloaded.
This is done by copying the files to the SD card and holding the DEMO button down while turning power on.
The open, close, demo files attached are named with their firmware numbers.
If you would like to change the file names to open, close, etc, feel free to do so. However, the file extension (.ocf, .ccf, .dmf) cannot be changed.
<Email>
Hi Ken,
Thanks alot for spreading the word on the new firmware for our Nexus Widebands. Make sure to let everyone know that if they have any questions they should give us a call on our tech support line 815.899.0801 for assistance. Other than that, I hope you enjoy your gauges.
Regards,
Steve
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
