INGs and TopSecret Rear Diffuser (Thanks Function Tuned!)
Old Mar 27, 2007 | 08:42 AM
  #41
Zexy's Avatar
Zexy
Damn.. The INGS rear is low enough already..
And that wing.. Wholy ****
Old Mar 27, 2007 | 08:45 AM
  #42
cubu's Avatar
cubu
is it me or is the sides of the difuser crooked?
Old Mar 27, 2007 | 08:52 AM
  #43
buzzardmountain's Avatar
buzzardmountain
^^I think he said on the first page that the left side vortex generator needed to be tightened....
Old Mar 27, 2007 | 09:17 AM
  #44
mdracer76's Avatar
mdracer76
LOLOLOL.. thanks for the books (darn photoshopers )
Here are the install pictures:
We laid up the diffuser to the kit.. and saw that the ends of the diffuser curved up a hair more then the ING's rear, So some cutting was required..
Once we lined up the rear brackets to get the right positioning.. we marked.
Here is Juan.. very carefully starting the first of a few painful, but skillful cuts.
One side down.
The next side.
Had to bend the bracket a bit to make it match the angle of the bumper a bit better.
Getting it perfect.
Couple more lay ups of the diffuser, some marks, measuring, then measuring again.. time to drill.
We did have to move this bracket forward to ensure that the mounting points would line up on the bumper.
2 out of 3 .. not bad.. should hold fine.
Same for the other side.
Bracket mounted P
Bracket mounted D
Middle Bracket on... just about there...
And some final shots.. and thoughts. The Rear brackets (that mount to the chassis) went on like butter, once we figured out which side is which.
Also with the Invidia Exhaust, we had to notch the diffuser a little bit so the Passenger side pipe would not interfere with the diffuser.
Again.. Thanks first and foremost Matt (THE TECH), and Dave & Juan (Function Tuned) For everything.
I'll try and get out of the office with some daylight left, and get some better pictures for you all.
~Mike
Old Mar 27, 2007 | 09:22 AM
  #45
mdracer76's Avatar
mdracer76
Originally Posted by icedout589
that license plate doesn't stand for the web design software named cold fusion does it?
Very nice addition...always have loved your car.
Thanks.. yea.. it originally did stand for CFML. I have not touched CFML in years.. but thought the plate was cool
Old Mar 27, 2007 | 10:56 AM
  #46
THE TECH's Avatar
THE TECH
Glad everything worked out. I wished I could have "bent" my brackets, but the original ones are fiberglass.
Old Mar 27, 2007 | 11:43 AM
  #47
mdracer76's Avatar
mdracer76
Really? Wow... thats interesting.
Old Mar 27, 2007 | 11:50 AM
  #48
PumpedVA's Avatar
PumpedVA
you said (Leaf Shooter Club)
to funny
Old Mar 27, 2007 | 01:30 PM
  #49
davidf's Avatar
davidf
Originally Posted by alshawi
niice, i like the way the diffuser sits in the rear bumper.
****, tires are wide enough?
Old Mar 27, 2007 | 04:07 PM
  #50
mdracer76's Avatar
mdracer76
K..Got Home from work.. pulled her out of the garage and took a few shots before the rain comes ....
A few things that we need to address... looks like the left vortex gen. was not loose.. but not quite mounted prefectly.. I'll get that fixed at Functioned soon enough....
Other than that.. I did see my first leaf shoot out the rear... it was kinda cool...
Old Mar 27, 2007 | 05:09 PM
  #51
buzzardmountain
Stunning!!!!!!!
Mucho props...
Old Mar 28, 2007 | 05:49 AM
  #52
THE TECH's Avatar
THE TECH
FYI, it looks like you put in the two center screws backwards. The heads go on the outside.
Old Mar 28, 2007 | 08:51 AM
  #53
GTSPEC's Avatar
GTSPEC
GTSPEC
Mike, boy are we glad you are part of the team. Absolutely stunning!!!
Keep up the good work, it's an inspiration to us all!!!
Old Mar 28, 2007 | 09:09 AM
  #54
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
wow, that make the diffuser look like it is made for that rear bumper!
Old Mar 28, 2007 | 11:46 AM
  #55
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Originally Posted by mdracer76
Now a prod member of the SBC, and the LFC (Leaf Shooter Club)
Can't wait to see it in person Mike. I thought some were saying that it wouldn't fit right on an INGs bumper.
nm: I see you had to modify the bumber. Looks great!
Old Mar 29, 2007 | 08:01 AM
  #56
alshawi's Avatar
alshawi
295s
Old Mar 29, 2007 | 08:04 AM
  #57
racin2fst4u's Avatar
racin2fst4u
Newbie
looks very hot man
Old Mar 29, 2007 | 08:12 AM
  #58
Rickdogg's Avatar
Rickdogg
Out of hiatus
It fits that rear really well. Nice
Old Mar 29, 2007 | 08:24 AM
  #59
Selski12's Avatar
Selski12
Hmm...Would that work with an exhaust like the Nismo? I wonder if that can be added to my setup...
Old Mar 29, 2007 | 10:22 AM
  #60
Chebosto's Avatar
Chebosto
the vortex generators should be flat on the bottom, but i guess you really can't do that with this install.. the air is suppose to come off the rear wheel, be 'smoothed' with the flat portion, and curl itself around the outter rounded loop and be shot backward, in counter-rotating vortices...idea is help shape airflow behind the car...
