help with carbon fiber
Old Mar 30, 2007 | 07:54 PM
LiLxDooD's Avatar
LiLxDooD
Default help with carbon fiber
Hey guys, its not about my z. but i have a carbon fiber exhaust can for my bike. i was messin around with a it today; long story short, a section of the clear coat/resin? came off the carbon fiber. Now that section is raw carbon fiber. what do you guys think i should do? should i just get a can of clear coat and spray that section? Will the back pressure push thru carbon fiber? it feels kinda soft. help me out guys thanks!
Old Mar 31, 2007 | 02:34 AM
Mapleleaf's Avatar
Mapleleaf
Try this link
http://www.fibreglast.com/content.ph...rksrc=FreeInfo
Old Mar 31, 2007 | 03:08 AM
Eazzy's Avatar
Eazzy
See if u can pick up a small quantity of clear Gel Coat and prep the surface or if the Can is not subjected to Hi heat, try some Clear epoxy---This is mainly for protecting the damaged area, not a top notch cosmetic fix. Surface prep is discussed in the above Link
Old Mar 31, 2007 | 07:32 AM
tonester1011's Avatar
tonester1011
CF God
clear will not fall into the cf. u need to use epoxy resin to fill the area, then sand til it is smooth. then u can clear it with clearcoat.
Old Mar 31, 2007 | 08:00 AM
LiLxDooD's Avatar
LiLxDooD
i can get this epoxy resin at mayb autozone??
Old Mar 31, 2007 | 08:02 AM
Eazzy's Avatar
Eazzy
Personally Id go to a auto paint supply
tonester1011
CF God
no...u have to go to a boat supply store. like a West Marine or something like that. it is a two part epoxy resin.
Old Mar 31, 2007 | 08:04 AM
tonester1011
CF God
they might not even have it. he needs resin that is super clear so u can see the weave on the cf. boat store will have that im not sure bout paint suplliers though.
Old Mar 31, 2007 | 08:42 AM
LiLxDooD's Avatar
LiLxDooD
well i called autozone and they said that they have a clear epoxy for repairing fiber glass. is that not right?
Old Mar 31, 2007 | 09:19 AM
tonester1011
CF God
it may be but fibergalss is different. fiberglass will get painted so the epoxy doesnt have to be clear. i have seen some clear epoxy resins that actually look yellowish when u use it on cf. i have used different kinds and the best that i have used is called System Three. u can give the stuff at autozone atry buit try it on something else to see how clear it actually is when it sets up. then go ahead and use it on the cf.
Old Mar 31, 2007 | 10:16 PM
LiLxDooD's Avatar
LiLxDooD
where can you get system three at?
Old Apr 1, 2007 | 03:41 PM
tonester1011
CF God
systemthree.com...sb-112 is the stuff u want
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
