Extending wires on gauges
Old Apr 10, 2007 | 03:55 AM
FibreGuy's Avatar
FibreGuy
Default Extending wires on gauges
I am installing 3 Autometer gauges and I have a sneeky suspicion that the wires for the gauges will be too short. Is it ok to add length to them or will the gauge not read correctly. The gauges are water temp, oil temp and oil press. All Autometer C2. So they are electric. With that being said I am pretty sure I know the answer but just want to hear it from someone who has done it before. Thanks for the info.
Old Apr 10, 2007 | 06:05 AM
THE TECH's Avatar
THE TECH
As long as it's just power, ground, etc. then there is no problem extending the wires.
Old Apr 10, 2007 | 03:52 PM
FibreGuy's Avatar
FibreGuy
Yeah, Question was not clear enough. I was actually thinking of the wires that go to the sensors themselves. Pwr, gnd etc I knew was ok to extend. The gauges are electric not mechanical. The instructions are quite basic, but no mention of this.
thanks
Old Apr 10, 2007 | 04:04 PM
Eazzy's Avatar
Eazzy
Im surprised they may not be long enough. Im a little particular with ----well everything. Use the same gauge ( Radio Shack has that small gauge ) Solder it and shrink tube it. Resistance shouldnt play a part.
Old Apr 10, 2007 | 05:52 PM
FibreGuy's Avatar
FibreGuy
I am more concerned with the water temp than the oil side of things. The water temp sensor is going in the upper rad hose which is fair distance from the drivers side pillar. Still haven't located a definative place to run the wires through the firewall on the drivers side. I already ran some wiring through the passenger side without much difficulty. I have yet to remove the lower drivers side dash or the dash section that houses the radio to maybe find a route between sides.
Old Apr 10, 2007 | 05:56 PM
THE TECH's Avatar
THE TECH
I'd have to see the sensor.
Old Apr 10, 2007 | 06:08 PM
Eazzy's Avatar
Eazzy
Did they suggest the upper hose ? That as a rule gives you fluccuating temperatures readings
350Z_Al
Oct 29, 2020 07:44 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
nanotech
Oct 2, 2015 05:02 AM
