hood struts, installed w/ pix
Old May 14, 2007 | 03:41 PM
tranceformer95's Avatar
tranceformer95
Default hood struts, installed w/ pix
This is actually the Tein hood strut kit, but modified. I painted them, the green was just ugly. And i did not use the lower mounts because the ones included in the kit would not let the hood shut w/o major cutting of the plastic covers.
So i searched and searched online and found an online store that has 10mm bolts w/ the pivot ball at the end. I replaced the lower mounts with these and all i had to do was just cut the small circle around the studs.
Old May 14, 2007 | 04:34 PM
Greedy4nismo's Avatar
Greedy4nismo
how's the lift? as open as stock? good job on the paint, btw
Old May 14, 2007 | 05:01 PM
Kwame's Avatar
Kwame
Can you post a link to where you found the 10mm bolt?
Old May 14, 2007 | 05:34 PM
VIZAGE's Avatar
VIZAGE
Should of painted them white. But still looks nice.
Old May 14, 2007 | 05:38 PM
THE TECH's Avatar
THE TECH
You don't need anything aside from the Tein kit to do this install.
Old May 14, 2007 | 05:46 PM
tranceformer95
How? I searched and searched and all i found was a thread where some welding was involved. And i don't weld.
Old May 14, 2007 | 05:49 PM
tranceformer95
Oh i lied, its really a 6mm ball stud.
Stupidly, i bought the whole ball joint, without first searching for just the ball stud.
http://www.midwestcontrol.com/buy.php?item=11
What i should have done was just buy the stud alone.
http://www.midwestcontrol.com/buy.php?item=3371
Old May 14, 2007 | 05:51 PM
tranceformer95
Thanks, I didn't measure but i'm guesstimating it lifts maybe (at most) an two or three inches less than stock. But its just fine b/c i'm short.
Old May 14, 2007 | 05:55 PM
tranceformer95
thanks. i was planning on painting them pearl white to match the car but i figured it would draw attention away from the rest of engine bay. that and my crawford plenum is powdercoated (the match now). But most of all i already had the black w/ metalic flakes n primer already in the basement... laziness overcomes all.
I'll probably get bored one afternoon and decide to repaint them pearl white to match my Z.
Old May 14, 2007 | 05:56 PM
THE TECH's Avatar
THE TECH
You just use what comes with the Tein kit. Nothing else needed. No welding needed.
Old May 14, 2007 | 05:58 PM
tranceformer95
Aaaaaah i see. I was just over-thinking. You meant you can just install the kit with the Tein kit alone. I was talking about the problem with the Tein kit and the lower mounts.
Old May 14, 2007 | 06:14 PM
THE TECH's Avatar
THE TECH
To clarify, I am saying that you can install the Tein kit exactly the way you have installed it without any additional parts.
Old May 14, 2007 | 07:34 PM
tranceformer95
How?
Old May 14, 2007 | 07:42 PM
THE TECH's Avatar
THE TECH
Simple. Just remove the screw on the fender and replace with the ball screw that comes with the kit.
Old May 14, 2007 | 07:45 PM
tranceformer95
Hmm mine never came with a ball screw. Maybe i have an older version of the kit?
Old May 14, 2007 | 07:50 PM
THE TECH's Avatar
THE TECH
What did they give you to attach the bottom of the strut to the engine bay?
Old May 14, 2007 | 08:09 PM
tranceformer95
here's the lower mounts that came with my kit.
The problem is that these pieces turns the struts inward to an angle that hits the plastic covers.
Old May 14, 2007 | 08:13 PM
THE TECH's Avatar
THE TECH
Weird. They must have totally changed the design.
Old May 15, 2007 | 12:04 AM
Armitage's Avatar
Armitage
I always remember them interfering with the plastic.
Old May 15, 2007 | 12:14 AM
turismo's Avatar
turismo
Looks good. I need to purchase some.
