got my cf hood keyed up
fuking haters i swear. i decided to not drive my z anywhere anymore. only to known places where there is a garage. got my hood keyed up. is there a way to get the sratch off of my seibon cf hood?
I always try to park within cameras view at stores, I met up with a friend and left my car at nordstroms parking lot all the way in the back and came back 3 hours later and someone took their key down the whole side of my car, down to the primer. I went to the 3 surrounding stores and my car was just out of reach of the cameras view, and my car is leased ughh, whats wrong with people in this world. I WILL kill someone if they **** with my Z.
Originally Posted by benDF
If it isn't too deep, and it's only gelcoated rather than clearcoated, you can try buffing it out. Might have to wetsand first depending on how bad it is.
Jim
Originally Posted by gimpster621
^somewhere in la. where can a get a wet sanded? does pepboys carry it?
edit: http://www.carcraft.com/howto/926/
"Contrary to popular belief, there's no great mystery in wet-sanding. In fact, the only reason it's called "wet" sanding is because that's exactly what it is--sanding with the addition of water. Why water? We use water because the ultra-fine sandpapers (like 800 to 2,000 grit) are easily clogged up by paint particles. And once sandpaper becomes clogged, it's useless for everything but scratching up your paint job. Oddly enough, all that is required to prevent this clogging is water. You simply run a little luke-warm tap water into a small bowl or sand near your tap, dip a small piece of ultra-fine sandpaper in, then commence sanding. Just be sure to keep dipping the sandpaper into the water or rinsing every now and then.
When sanding paint or clear coats always use 1500 grit or finer sandpaper for this (I use 2000 grit usually). Stop and dry off the car body every now and then to be sure you're not sanding through the layer being sanded. Be especially careful of ridges or sharp details in the casting. It's very easy to inadvertently sand through the paint on raised areas. "
^yea i just tried some meguires scratch X. it got rid of the white scratch but i can still see the scratch. i think im going to call a couple shops and see if they can get it off. if not im gona do a paint scheme and paint the hood.
Originally Posted by turismo
Sorry to hear about that man. Hope you find who did it!
