Redoing the Interior!
Old Jun 3, 2007 | 08:06 AM
A_Del's Avatar
A_Del
Default Redoing the Interior!
I am going to remove the seats out of my car and put in some racing seats (Bride or Sparco, any suggestion?) and i was wondering what i would need to buy. I know i need a harness bar, the seats, a harness. but is there any thing else i could need. Thanks.
Also what seats would look besr with a black exterior?
Old Jun 3, 2007 | 08:09 AM
SuperBlack350z's Avatar
SuperBlack350z
i prefer Bride seats. You will needs seat brackets and sliders for each seat. Harness bar and harnesses are up to you if you want it or not.
Old Jun 3, 2007 | 08:16 AM
A_Del's Avatar
A_Del
Do you have a web site you could recomend. Also what seats of bride do you prefer?
Old Jun 3, 2007 | 08:19 AM
SuperBlack350z
here are a page full of bride seats http://www.intensepower.com/brideseats.html
i prefer the BRIDE Low Max GIAS Seats. They are really nice.
Old Jun 3, 2007 | 10:22 AM
A_Del's Avatar
A_Del
do you know what steps i would have to go through to setup a haness bar in the car?
A_Del's Avatar
A_Del
*Harness*
Old Jun 3, 2007 | 02:15 PM
A_Del's Avatar
A_Del
?any one?
Old Jun 3, 2007 | 03:46 PM
kyoeyes's Avatar
kyoeyes
to put racing seats in, all you would need are seat rails, sliders(if your seat isn't a bucket one), and the seats, harness and other items are extra items you might want in the interior but just to have the seats in thats all you would need
Old Jun 3, 2007 | 03:56 PM
SuperBlack350z
a harness bar is just a couple of bolts from one side to the other. Easy and straight forward.
It seems like you are talking about a roll cage where you strap your harness behind you.
Old Jun 3, 2007 | 04:04 PM
A_Del's Avatar
A_Del
Oh, okay. I got the two mixed up. will Vielside seats need slider?
Old Jun 3, 2007 | 04:05 PM
noodleman's Avatar
noodleman
you probably don't need the harness if you're not tracking your car..if you get the right rails/silders, you can attach your seat belt buckle to the rails and use your regular seat belts.
for black cars, i prefer Burnt Orange or Red seats. Black would be nice as well if you're going for the "stealth" look.
Old Jun 3, 2007 | 04:13 PM
A_Del's Avatar
A_Del
Well i want to put Takata harrnesses in the car with the Vielside seats, and i want the standard belt off the car, but i don't want the harness to be for show(tad bit ricer for me). So my next question is what problems will i run into replacing my seats? (Any side curtain airbag issues, door clearance?)
Thanks
Old Jun 3, 2007 | 04:23 PM
SuperBlack350z
Thanks
I'm goign to try to sum it up for you so you dont' have to ask any more questions.
Every seat, you will need a bracket. If you want ot move back and forth for adjustment, then you will need sliders.
If you want to get seat belt harnesses, the safe thing is to get the harness bar so you get a 90 degree with the belt. I have seen cheap people do the unsafe way and just bolt the harness down to the brackets.
Depending on seat height, size, those are the problems. you might be sitting higher than stock which their are low profile brackets so you can sit lower.
You will get an air bag light if your stock seats have airbags in them and the harness is not plugged in.
when you get seats, do it properly and dont' get cheap stuff because its very important and is unsafe if you do a half *** job on it.
good luck
Old Jun 3, 2007 | 04:35 PM
A_Del's Avatar
A_Del
Can any one direct me to a thred that explains how to get the airbag light to turn off?
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
