How do i use floor jacks with Veilside V1 skirts? Pic
Old Jul 2, 2007 | 10:34 PM
tienlo's Avatar
tienlo
Default How do i use floor jacks with Veilside V1 skirts? Pic
Just a quick question, i know you can jack up my car with the rear differential like in the pic here, but do i have to take off the skirts to jack up the car with the factory points?
Attached Thumbnails How do i use floor jacks with Veilside V1 skirts? Pic-supra_3232.jpg
Old Jul 2, 2007 | 10:37 PM
Mazinger Z's Avatar
Mazinger Z
I just put it a little past the rear-side skirts. It's doesn't make the car as high but it does the job. Is that the highest you can raise your car with the jack?
Old Jul 2, 2007 | 10:39 PM
702Fairlady's Avatar
702Fairlady
Or you could get a low profile racing jack. They are at autozone for about 100 bucks. It slides right under my INGS skirt with no problem.
Old Jul 2, 2007 | 10:40 PM
tienlo's Avatar
tienlo
ok, so its fine to slide past the skirt and jack from the metal? That's a pic of my new kit being installed, i haven't taken it home yet. Thanks 4 quick replies
Attached Thumbnails How do i use floor jacks with Veilside V1 skirts? Pic-supra_3233-3.jpg
Old Jul 3, 2007 | 05:12 AM
y0shi's Avatar
y0shi
i made a ramp out of pieces of 3 pieces of wood.. drive up the ramp and jack the car up like normal.. it worked for me, i had ings sides.
Old Jul 3, 2007 | 07:50 AM
MustGoFastR's Avatar
MustGoFastR
Yes, just past the factory jack point, behind the little lip with the notches you straddle with the scissor jack, there is a little reinforced area that you can jack from. I ussually put a piece of 2x2 wood on top of the jack and line it up right behind the weld seam ridge.
Old Jul 3, 2007 | 08:20 AM
tonester1011's Avatar
tonester1011
CF God
yea they make a low profile jack but i still cant get that under my greddy sides...use a few boards and drive up them on whichever side of the car u want to jack up.that will do it for u.
Old Jul 3, 2007 | 09:44 AM
synth19's Avatar
synth19
I have the central20 sides and even the low profile jack doesn't work. I recommend getting some small ramps to get the clearance. Once you get the car on the ramp, then use your jack to get the car up. Last time we had the car up, we didn't have ramps. So I had to jack it from the pumpkin, then use another jack for the sides once I had enough clearance. WAY too much work.
Old Jul 3, 2007 | 10:04 AM
Mazinger Z's Avatar
Mazinger Z
I think he's talking about where to put the jack-stands. Not how to jack up the car...
Old Jul 3, 2007 | 11:58 AM
synth19's Avatar
synth19
^ Doh. Totally misread the question. heh
Old Jul 3, 2007 | 02:54 PM
devildoc's Avatar
devildoc
I found this picture in a thread. Is it ok to use the rear lower link? I also just noticed that only one side has a jackstand
drsifu
Dec 19, 2015 04:08 PM
LunchBox20
Oct 20, 2015 10:22 PM
ddegrande21
Sep 6, 2015 11:15 AM
SKiDaZZLe
Mar 17, 2003 10:03 AM
