NISMO Steering Wheel?
Old Oct 20, 2007 | 09:01 AM
  #41
MyFairladyZ2006's Avatar
MyFairladyZ2006
That one looks really good but if the airbags wouldnt work I dont think I would get it.
Old Oct 20, 2007 | 09:14 AM
  #42
DeusExMaxima's Avatar
DeusExMaxima
Originally Posted by Chebosto
question is:
will the JDM airbag FIRE at all on the USDM cars with just 1 airbag input? i mean the whole point of you getting an aftermarket steering wheel with an airbag is for it to work properly.... else if you're fooling the car with the 2nd resistor, when its time to go in an accident it may or may not set off.
hopefully you looked into it. else it'll be just as if you put in a non-airbagged steering wheel.
You're right. I havent found the solution, but Im still looking.
Old Oct 20, 2007 | 07:35 PM
  #43
intense350's Avatar
intense350
Red face
NISMO Z-tune Steering wheel w/ airbag
maybe a blonde moment here, but this wheel, is it smaller than the stock wheel or the same size? that would help in the decision making process. TIA.
Old Oct 20, 2007 | 07:50 PM
  #44
Zivman's Avatar
Zivman
the Z-tune is roughly 355mm. The stock wheel is 370mm
Old Oct 21, 2007 | 10:07 PM
  #45
DeusExMaxima
I found that a 2 ohm resistor when plugged into the airbag connector tricks the computer into sensing an airbag. Since there is aconnector plugged into the airbag, the bag will work. I hooked up a 2 ohm resistor and no airbag lights were triggered. LOVE the new steering wheel.
Old Oct 21, 2007 | 10:18 PM
  #46
Chebosto's Avatar
Chebosto
yes. we know that a 2ohm resistor fools the system in thinking that a non-deployed airbag is still in-line, however i'm just thinking, when the computer is sending the signal to fire, especially for the steering wheel, they're expecting infinite resistance (open circuit) as the final signal. hopefully its in series and once one bag goes. that'll be sufficient. what did the dealer say, or who installed it for you?
Old Oct 28, 2007 | 06:51 PM
  #47
DeusExMaxima
I dont deal with the stealership. They never make any sense. I did the install.
Old Oct 29, 2007 | 03:33 PM
  #48
ChinaClipper's Avatar
ChinaClipper
I found that a 2 ohm resistor when plugged into the airbag connector tricks the computer into sensing an airbag. Since there is a connector plugged into the airbag, the bag will work.
Uh, don't be so sure that your airbag will work right. US airbags are supposed to be dual level actuation - they will blow as designed , or will blow at a lesser force at slower speeds. That is why the US bag has two connectors - each for the different inputs as determined by the onboard sensors. The JDM airbag with a single connector is designed to blow full-tilt only. In a lower speed situation, as determined by the onboard computer, your signal to the disabled connector will mean no airbag deployment at all.
Old Oct 29, 2007 | 03:46 PM
  #49
GodSendsDeath's Avatar
GodSendsDeath
I like the other version, version A. Hmm looks like my first mod pricey though huh.
Old Oct 29, 2007 | 03:51 PM
  #50
Z04's Avatar
Z04
sorry, but losing a important safety feature and my cruise control is not worth it IMO
Old Oct 29, 2007 | 06:21 PM
  #51
350zrn35's Avatar
350zrn35
You want this MOMO one? or this NISMO R34 GT-R Z-tune one?
Attached Thumbnails NISMO Steering Wheel?-jdmmomo2.jpg   NISMO Steering Wheel?-nismoztune.jpg
Old May 14, 2010 | 03:53 AM
  #52
MIX350Z's Avatar
MIX350Z
Forgive me for reviving such an old thread, but I have to take the chance.
Can you still get your hands on any of these airbag equipped steering wheels?
Still have one lying around, that you'd be willing to part with for what you deem the right price?
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
