questions about rear splash guard~
Old Aug 21, 2007 | 03:57 PM
findrock2's Avatar
findrock2
Default questions about rear splash guard~
first, to be able to install those guards i need to drill some holes.
i've just put on the front ones with turning the front wheels.
but since the rear wheels are not turnable~ do i have to jack up the car n' take out the rear wheels then install the rear guards? instructions doesn't give any info on it. any help would be nice.
thx
-rock
Old Aug 21, 2007 | 04:03 PM
Andres30o0's Avatar
Andres30o0
I took mine off w/o removing the rear wheel or putting the car on a jack. Shorty phillips should do the trick. If you need to drill holes in your side skirt (cringes), then you'll have to remove the rear wheels to have enough space for the drill.
Old Aug 21, 2007 | 04:11 PM
35TH ANY's Avatar
35TH ANY
Yup, either a shorty or an offset screwdriver should do the trick without having to remove the wheels.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Aug 21, 2007 | 09:08 PM
findrock2's Avatar
findrock2
thx guys.
but the instruction sheet says to drill holes then put screws onto it. im not having trouble with phillips, but the drilling~~~ hand drill too big. did you guys put it on with the 3m tape???
Old Aug 21, 2007 | 09:09 PM
findrock2's Avatar
findrock2
p.s. IM INSTALLING IT~not to take off
Old Aug 22, 2007 | 06:38 AM
35TH ANY's Avatar
35TH ANY
Check out a "right angle drill".
Old Aug 22, 2007 | 03:35 PM
findrock2's Avatar
findrock2
thank you guys. so i ended up taking out 2 rear wheels n' put it on. look great
416blueZ
Jun 11, 2024 10:56 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
