Damaged CF Lip!!
Old Sep 10, 2007 | 03:12 PM
ShineAutoProject's Avatar
ShineAutoProject
Shine Auto Project
Originally Posted by sry110
Just my insight on reinforced fiberglass (or FRP)....my VeilSide V1 lip is FRP and it cracked very easily in one of the corners (where it wraps around into the wheel well) when we were test fitting it. I agree it is a little more forgiving than straight fiberglass, but I think it tends more towards fiberglass than plastic with regards to material properties.
Another thought is that although fiberglass parts break instead of bending, it is much easier to repair fiberglass than to repair urethane. Urethane will bend but it will also tear, and short of melting/stretching material back into place there is no great way to repair it. Although I do think that urethane would be a better pick for the front end, because you would have to hit something pretty hard to tear a hole in the front lip.
Your Veilside V1 lip IS fiberglass. FRP = fiberglass.
Old Sep 10, 2007 | 03:16 PM
wckdclw's Avatar
wckdclw
you did a really good job fixing that lip, i had to do the same to mine where it cracked on the side
Old Sep 11, 2007 | 06:12 AM
james840a's Avatar
james840a
Thanks guys i try to do my best when fixing things. I just need to paint the low part of the lip and the underside. But that nothing.
Old Sep 11, 2007 | 06:28 AM
boostedef's Avatar
boostedef
what did you do to fix it ?
Old Sep 11, 2007 | 07:15 AM
james840a's Avatar
james840a
The areas, that had cracked or chipped out resin, i cleaned out. If there were areas that was about to come out, i'd chip it out. The CF mat was still intact, except were the hole was. I patched the hole with just fiberglass mat (kind of wished i had some CF mat but oh well) and filled the areas with resin till hardened, Sanded with different sand papers, and then buffed with rubbing compound.
Old Sep 11, 2007 | 04:46 PM
Wholey Smokes's Avatar
Wholey Smokes
Awesome job.
issyz
Jul 2, 2017 03:04 PM
Cashwin
Oct 1, 2015 06:36 AM
FromGtoZ
Sep 20, 2015 03:41 PM
