Stupid question about Hood Dampers
Old Oct 7, 2007 | 11:33 AM
JZurita's Avatar
JZurita
Default Stupid question about Hood Dampers
I bought dampers similar to these:
http://cgi.ebay.com/ebaymotors/03-07...spagenameZWDVW
Got them on a few minutes ago, but they seem locked and I can't figure out how to close my hood. I tried twisting them back and forth and nothing seems to work. Am I missing something here?
Old Oct 7, 2007 | 11:44 AM
JZurita's Avatar
JZurita
anyone?
Old Oct 7, 2007 | 11:49 AM
Spork's Avatar
Spork
just press down hard. If they haven't been compressed since they were made and shipped, they may just be sorta stuck like that. Some good force should compress them.
You can take them back off, rest the end on a block of wood, and hit the other end with a rubber mallet until the shaft moves.
Old Oct 7, 2007 | 12:32 PM
VIZAGE's Avatar
VIZAGE
When new, there pretty stiff. But be careful just in case. They'll break in over time, where you wont notice it. Try spacing your hands on each side of the hood and close with even pressure on both sides. Instead of just in the middle, like usually. Siverstone-Z had a good suggestion.
Old Oct 7, 2007 | 01:18 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default My CTD...
dampers were super stiff out of the box. The suggestions above will work and be patient...
Old Oct 7, 2007 | 04:06 PM
JZurita's Avatar
JZurita
Thanks for the help fellas. Got my rubber mallet in hand...
Old Oct 7, 2007 | 04:14 PM
jaspendlove's Avatar
jaspendlove
update? did it work?
Old Oct 7, 2007 | 05:31 PM
JZurita's Avatar
JZurita
That thing was a *****... I tried the mallet for a while, then sprayed some WD40 and pushed down on it using a folded up towel and it finally worked... kept doing it till it was easier push and put them back under the hood... Works like a charm and certainly worth the 60 bucks... I appreciate the help!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
