8000k lights
Old Dec 6, 2007 | 08:36 PM
henry j's Avatar
henry j
Originally Posted by BojanC350z
no, if i ask for help on how to do someting if you want reply with the awnser how to install the bulb, whats the point of telling me its ricer? is it your car im putting it on? no its mine so if your gonna tell me how to put them on thank you if your going to write someting stupid like that whats the point? then dont even write anything
im wit u on that
Old Dec 6, 2007 | 09:00 PM
Escobar's Avatar
Escobar
a lot of the time the bulbs arent even 6 or 10 K or whatever. Since there are so many ignorant people out there who think bigger is better they try and get the most K bulbs when in fact like dave was sayin, its the opposite. It is unsafe and pointless. Just make sure if you do decide to go that high, make sure it is a reputable company(phillips) or something.
Old Dec 7, 2007 | 07:34 AM
3fittyBiH's Avatar
3fittyBiH
bojan, are you from serbia??
Old Dec 7, 2007 | 11:36 AM
BojanC350z's Avatar
BojanC350z
was born in zadar, croatia.. but im serbian..why? what are u
Old Dec 7, 2007 | 01:44 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I feel that if you cant change a simple headlight bulb you shouldnt be modding a car. Some may disagree just how I feel. Its as easy as jacking up the car, removing the wheel, taking the inner fender plastics out and swapping bulbs. Will take 10 min per side. I you cant take off a wheel, two 10mm bolts and some clips I feel bad for you.
Old Dec 7, 2007 | 03:17 PM
Escobar's Avatar
Escobar
for real man, you can handle it
Old Dec 7, 2007 | 03:34 PM
Mrpeepers's Avatar
Mrpeepers
just give it a try! oh and i switched to 8k from halogen and i can see much better on a 240sx
Old Dec 7, 2007 | 08:58 PM
BojanC350z's Avatar
BojanC350z
no i can do it i just wasnt sure if i can change it that way, i changed my parking bulbs removing the inner fender plastics thats the point of this post asking if i can do it the same way
Old Dec 9, 2007 | 07:11 PM
ChrisR's Avatar
ChrisR
well i guess people with halogen head lights are putting other people in danger because of their light out put....im pretty sure u can see more with 8000K than halgen bulbs!
Old Dec 10, 2007 | 09:21 PM
3fittyBiH's Avatar
3fittyBiH
bosnian, from sarajevo! sta ima? hah
Old Dec 11, 2007 | 06:01 PM
neoveon's Avatar
neoveon
to me, 5k is probably the best: brightest and pretty good looking too.
btw, can someone tell the difference between D2R and D2S?... I know our Zs are equipped with D2R.
Old Dec 12, 2007 | 08:14 PM
koolboyztn's Avatar
koolboyztn
The main difference is the U-shaped masking on the D2R that blocks out unpredictable light in certain directions. Also, the base has different notches. Name of base is P32-d2 for D2S and P32-d3 for D2R. D2R was developed so that Mercedes could still use their reflector based headlights in the mid 1990s. They did not want use projectors like BMW. A glare box inside the headlight could have been used to accomplish a straight line, but a mask painted on the bulb was cheaper to make and had better precision. Other (near) luxury cars (Lexus, Infinity and Acura) followed Mercedes and equipped their cars with D2R bulbs in reflector based headlamps. Using a D2R in anything else than a OEM HID headlight designed for the D2R bulb makes no sense. It will only reduce output. Some HID kits comes with D2R bulbs. Some amateur kit designers will even claim that D2R genrally reduces glare in a retrofit. This is nonsense. The D2R bulb masking is around 3-4 a'clock and 8-9 o'clock when bulb is in right position. Those are not the (only) sectors that creates glare.
As an example, here is the data on Philips 2 versions:
D2S: 3200lm, 4250K, 91lm/W, 35W
D2R: 2800lm, 4150K, 80lm/W, 35W
Zs (2006 up)using D2S not D2R
Old Dec 12, 2007 | 09:17 PM
07carbonsilver's Avatar
07carbonsilver
my 07 had D2R bulbs
Old Dec 12, 2007 | 10:46 PM
redlude97's Avatar
redlude97
Originally Posted by 07carbonsilver
my 07 had D2R bulbs
From the factory? Impossible, the bases are different, they would have had to hack a notch into it for them to fit
Old Dec 13, 2007 | 02:52 AM
  #38
ghost's Avatar
ghost
Originally Posted by dave079
Why would you get 8k lights? Its a dumb idea. They look ricey and you cant see crap with them. The light output drastically decreases as you go up higher. 6k should be the max.
So 10% decrease is drastic?
Let him do what he wants and quit being useless.
Old Dec 13, 2007 | 10:09 AM
  #40
redlude97's Avatar
redlude97
10%? Where did you get that number from? Try 25+% at 5800k, and even more as the kelvins go up
