gotta push the trunk button twice
Old Feb 1, 2008 | 06:20 PM
henry j's Avatar
henry j
Default gotta push the trunk button twice
As the title says, i dont understand why but i have to push the trunk button twice for it to open. the first time i hold it down it pops up but its still doesnt open. lol anyone else have a problem like this? btw i have an 03.. any ideas thanks for the help
Old Feb 1, 2008 | 06:21 PM
Catchmeifyoucan's Avatar
Catchmeifyoucan
i have the same problem too.
i have to push the remote twice to open the trunk.
Old Feb 1, 2008 | 06:25 PM
henry j's Avatar
henry j
so how do u think we can fix this?
Mansmind's Avatar
Mansmind
if the hatch struts are worn and/or too stiff, they will not move the hatch far enough to get over the catch. In other words, it SHOULD pop up just enough on the first push to clear this.. if it doesn't.. you have to push it again in order to get it open.
Old Feb 1, 2008 | 06:28 PM
henry j's Avatar
henry j
soo i need to get new struts for the hatch? because its not like i have this problem once in a while its everytime i want to open the trunk. i was thinking something had to be oiled/lubed..?
Old Feb 1, 2008 | 06:32 PM
Mansmind's Avatar
Mansmind
Yeah they're probably worn if you have an 03. In my particular case (07) I replaced the stockers with stainless steel (and much stiffer). In fact they're so stiff that I get the same issue you guys do.
Old Feb 1, 2008 | 06:33 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You might try the penny trick.
There are two rubber bumpers that are about 1-1/2" long on the lid.
Twist them to remove.
Pull the spring out and drop a penny (I used nickels. Made me feel rich!). Replace the spring, then put the bumpers back in the lid.
You may have to put more than one coin in, but it definitely gives a little more pop.
Old Feb 1, 2008 | 06:36 PM
henry j's Avatar
henry j
kinda confusing but ima give it a try thanks
Try&keepup's Avatar
Try&keepup
+1 This worked for me.
Old Feb 1, 2008 | 06:40 PM
TreeFiddyZee
Do WHAAAAT!?
Sorry. It sounded a lot better in my head. It's actually very simple.
I meant deck lid/hatch by the way instead of just lid.
Old Feb 1, 2008 | 06:51 PM
Eazzy's Avatar
Eazzy
Also helps to put a little armorall or whatever on the gasket seal, It tends to stick and not allow a good release...Picture this for clarification. If you put glue on the seal, the trunk wouldnt open at all
Old Feb 1, 2008 | 06:53 PM
henry j's Avatar
henry j
by gasket seal, do you mean the U shaped thing?
Old Feb 1, 2008 | 07:04 PM
Escobar's Avatar
Escobar
i used nickels, should do the job.
Old Feb 1, 2008 | 08:46 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Mine has been doing the two push thing since I bought it in 03.
Not a biggee
Old Feb 1, 2008 | 09:00 PM
350ZTheStandard's Avatar
350ZTheStandard
Think this has to do with the cold weather???
Old Feb 1, 2008 | 09:04 PM
Escobar's Avatar
Escobar
who would of guessed?
Old Feb 1, 2008 | 11:14 PM
Kuruma-san's Avatar
Kuruma-san
+1 on this, i had a buddy with the same problem, he replaced his struts and it fixed the problem for him
Old Feb 2, 2008 | 12:08 AM
Forever Z's Avatar
Forever Z
My '06 does the same thing everytime I try to open the hatch. In fact, it's gottn so bad that now I have to pull on the hatch as I hit the button. Otherwise, it wont open. I did take it to the dealer once to have them look at it but of course it worked fine at the dealer
Old Feb 2, 2008 | 10:54 AM
Greedy4nismo's Avatar
Greedy4nismo
mine does the same with new hatch struts, so i'm guessing i need to try the penny/nickel trick
Old Feb 2, 2008 | 11:05 AM
Eazzy's Avatar
Eazzy
I mean the trunk seal...yes. It in a sense acts like a spring if it dosent stick to the mating base ---Try waxing that area also.
If the lid is trying to pop up and cant because the seal is sticking, even slightly.....correct it
