Headlight is out
Just got my Z back from the paint shop tonight 10 min before they closed and I found out just now that my left headlight\blinker is not working.
Any advice on what to check so I don't have to wait until monday night after work?
Do I really have to take the front wheel off to check behind the light?
Is there seperate fuses from left to right because the right one works fine.
Thanks...
Thanks...
If your looking to replace the bulb......yeah it's pretty retarded. You have to pull the black plastic piece down which only comes easy if you take the tire off. I put PIAA lights in mine and it was a ***** if I didn't do it that way.
Is it possible they just didn't plug the light back in? Did they have to remove the headlights to paint the car? That's a pretty common thing if so.
Fixing it isn't a big deal. If for some reason you can't get to the harness from the wheel well, you'll just have to pull the front bumper off and pull the light out to check out what's going on. 45 minutes max.
