vented hoods: function or show?
Old Feb 19, 2008 | 07:10 AM
rbfd's Avatar
rbfd
Originally Posted by mrpratt
still have the template?
Yes Please!
Old Feb 19, 2008 | 07:11 AM
Fluid1's Avatar
Fluid1
Only one time have I ever seen any real testing done on a 350Z. I believe the hood tested was a Seibon, with a large symmetrical vent on either side.
The Seibon did not decrease engine bay temps, it actually raised them.
Old Feb 19, 2008 | 07:15 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
No, I don't think so. It's on a buddies car now here in Orlando. It might be on here somewhere if you do a search.
Old Feb 19, 2008 | 07:22 AM
iStan's Avatar
iStan
ZR
I cannot really tell during a drive, but at idle, those vents make me smile seeing all the damn heat rise out of them.
Old Feb 19, 2008 | 07:26 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Explain that please. How is the atmosphere going to increase the temperature of the engine bay when its at a lower temperature. ( whats a typical engine bay temp?)
Its either do nothing or cool the engine bay.
Old Feb 19, 2008 | 07:31 AM
Quamen's Avatar
Quamen
I am going to cut my stock hood and have vents put in.
I am going to have a large one up front to vent the hot air from my radiator and some over the headers since I no longer have heat sheilds on my Strup headers.
Old Feb 19, 2008 | 07:33 AM
r0mey's Avatar
r0mey
my vented hood works great for cooling off my engine bay
Old Feb 19, 2008 | 08:09 AM
Fluid1's Avatar
Fluid1
Sigh.
The stock hood on the Z is engineered itself to vent out air and keep the engine bay cool.
Aftermarket hoods are designed to sell, to make money, and are not tested.
Just because it looks like it will work better does not mean it will.
Old Feb 19, 2008 | 08:10 AM
Fluid1's Avatar
Fluid1
Well, test the temperatures in your engine bay before, and after.
Just because you 'think' that a hole in your hood at a certain place will cool the engine bay more does certainly NOT mean that it will work that way in the real world, at speed.
Old Feb 19, 2008 | 08:13 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Sigh.
That doesn't mean there isn't room for improvement or in this case, more cooling. Thats like saying SRT4's don't need a FMIC because Dodge "engineered" it to be cool with the top mount.
Commonsense would tell you UTH temps would drop if the atmospheric temperature was allowed in through gapping holes above the engine bay.
Cooler air+more air flow = lower temperatures
gothchick's Avatar
gothchick
Has anyone logged oil temps with a standard hood, then with a vented hood?
Old Feb 19, 2008 | 08:28 AM
Quamen's Avatar
Quamen
I fully understand what you are saying but I seem to think that you have no idea what my setup is so you would have a hard time understanding the necessity of my vents.
Old Feb 19, 2008 | 08:34 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Here's one way a hole in the hood could hinder, rather than help: IF the hood is a high pressure area, due to the fluid dynamics of the air rushing across it at a speed slower than somewhere else (for example, hitting the windshield and rushing back down), air could actually be pushing INTO the engine bay through the holes(s) in the hood, and increasing the air pressure in the engine bay. This would impede airflow into the bay from the front, thus reducing air flow across the radiator (and any front mount IC's or oil coolers), thus increasing oil and water temps.
Granted, I don't think this is the case, but it is a possibility. Fluid dynamics is a tricky thing.
Old Feb 19, 2008 | 08:48 AM
gothchick's Avatar
gothchick
Isn't your rad (or IC) mounted horizontally instead of vertically?
Old Feb 19, 2008 | 08:56 AM
Quamen's Avatar
Quamen
Yes
Old Feb 19, 2008 | 08:57 AM
03Zilverstone's Avatar
03Zilverstone
Originally Posted by 04LIQUIDSILVER
shut letme know I you can get in touch with hem..
This is all I could come up with.
https://my350z.com/forum/showthread....smo+hood+vents
Disabled links to templates here, but with posts from members that have or had them:
Old Feb 19, 2008 | 09:08 AM
MaRbLe's Avatar
MaRbLe
Running Top Secret, they have the vents right above where the headers are located so I would definatly say its functional....
Old Feb 19, 2008 | 11:04 AM
  #38
DaProdigy's Avatar
DaProdigy
damn so nobody has a current link to get the template from?
Old Feb 19, 2008 | 11:29 AM
  #39
Abishop's Avatar
Abishop
^ +1!
Old Feb 19, 2008 | 08:30 PM
  #40
03Zilverstone
I'd say the best bet is to pm the people that posted up in those threads and see if the still have them. Or ask if someone that has done it would be nice enough to make a new template.
