Headlight trouble
Old Mar 10, 2008 | 03:54 PM
Willowns's Avatar
Willowns
Default Headlight trouble
alright guys. Well i switched the caseings on my stock headlights for some new ones. I Sealed everything with silacon sealant and they didnt fogg up. BUUTTT I tok the car to a car wash today and after the wash terrible condensation in the headlights. it is terrible. and i worked my *** off to put these in. What did i do wrong??? I promise that i sealed everything off fully. any help please? I am very desperate.
And mods, please dont move this, i need help!!!
Thanks, Will
Old Mar 10, 2008 | 04:01 PM
LaoSiFu's Avatar
LaoSiFu
Here is my input.
You're going to take it apart again and reseal it. To be honest, I always put in more than enough as a precaution. Bake again and push them in. Pretty much you want it to tuck right in. Then check the headlights for any cracks. Check around the area where the lens out and the back part touches. There might be possible there is a hair crack.
Let me know if that helps.
~Robert
Old Mar 10, 2008 | 04:02 PM
TreeZ's Avatar
TreeZ
i thought i sealed mine off when i blacked out my headlights. i guess i was wrong. i took them out, dried it out and sealed it again. no problems ever since. i guess i'm saying to check seals again. its worth a shot. . .
Old Mar 10, 2008 | 04:08 PM
Willowns's Avatar
Willowns
ok well, my HID's are not working....I guess that meens that they are blown....or just wet? I am so screwed...lol. anyways........I am gunna get flamed for this....but i used bathroom silicon sealant....was that a bad chioce? (it was all i had!!!!)
Old Mar 10, 2008 | 04:16 PM
LaoSiFu's Avatar
LaoSiFu
I can say the use of bathroom sealant is bad since I never had any experience with it.
Okay since your HID is not working try this now. When you take it apart, take off the ballast. I assume there is water in there. Shake it off and let it dry under the sun. Then reinstall and let me know how that go.
~Robert
Old Mar 10, 2008 | 04:20 PM
Willowns's Avatar
Willowns
what is the ballist??? and how do i take it off lol
Old Mar 10, 2008 | 04:24 PM
Rowlett's Avatar
Rowlett
Id check all the conections make sure none are wet...
Old Mar 10, 2008 | 04:26 PM
surfcity40's Avatar
surfcity40
Thanks, Will
you certainly do. Here:
http://dictionary.reference.com/
Old Mar 10, 2008 | 04:32 PM
LaoSiFu's Avatar
LaoSiFu
It is a gray looking block. It it located on the bottom of the headlights. You'll need a philip screwdriver to remove.
Here is my DIY on headlights. It should help you (I hope).
https://my350z.com/forum/showthread....+Black+Housing
~Robert
Old Mar 10, 2008 | 05:33 PM
Nic@CiNcity's Avatar
Nic@CiNcity
If that doesn't work, I will buy these broken lights off you and get you a set of working ones if you wish.
Old Mar 10, 2008 | 06:39 PM
DManator's Avatar
DManator
I get condensation in my headlights too after I painted them, but it only appears in the morning or when it's really humid. I'm too lazy to take them apart and try to reseal them lol. My right headlight lens looks horrible, I think all the condensation left water spots on the inside.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
pslamp32
Feb 8, 2017 09:07 AM
JGee450
Sep 30, 2015 04:32 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
