Door Handle Screw
Old Mar 15, 2008 | 03:31 PM
blinkme323's Avatar
blinkme323
Default Door Handle Screw
Hey guys I'm taking off my drivers side door panel and everything is going fine, however I can't get the rubber plug off from behind the door handle. I've tried just about everything to pry it off, any advice?
Old Mar 15, 2008 | 09:16 PM
Advent7's Avatar
Advent7
Do you mean the ones covering the hole so you can access the screws holding on the door handle?
Old Mar 15, 2008 | 09:30 PM
cdoxp800's Avatar
cdoxp800
If you have an 06 + there is not a screw there. See my pic below. You don't need to remove it on the 06 +. I removed to only find the door still would not come off. There was a bolt/screw behind the cover it's self
Old Mar 16, 2008 | 01:18 AM
Advent7's Avatar
Advent7
Oh that one, yeah you don't remove the rubber plug at all you just take the plastic piece out, like the plastic cover.
Old Mar 16, 2008 | 10:00 AM
cdoxp800's Avatar
cdoxp800
You got it.
350Z_Al
Oct 29, 2020 07:44 PM
