Top Secret Diffuser Exhaust Fitment List
Old Aug 3, 2012 | 03:48 AM
  #121
sry110's Avatar
sry110
Originally Posted by bimmertech
don't worry man, i have the large tip legalis R and the diffuser and it looks good.
i did have to cut about 2" away right around the main pipe as it was rubbing.
Thanks for the encouragement and the heads-up. Could you post a few pics of yours?
EDIT: Moot point. I just ordered an Invidia Gemini true-dual. I may test fit the diffuser with the Fujitsubo, but ultimately will be running it with the Invidia. I'm pretty sure I will need to trim the front of the diffuser in two spots to clear the pipes leading up to the muffler, but that's OK - out of sight, out of mind.
Old Aug 12, 2012 | 05:12 PM
  #122
sry110's Avatar
sry110
Invidia Gemini will fit with modification. The driver side rear pipe (leading up to the muffler) interferes with the front lip of the diffuser, but you don't have to cut away very much to get clearance.
Old Aug 14, 2013 | 06:07 PM
  #123
freddys 350z's Avatar
freddys 350z
anyone have the TDX2 with this diffuser? about to buy this diffuser.
Old Aug 18, 2013 | 07:23 PM
  #124
freddys 350z
anybody??
Old Aug 19, 2013 | 09:03 AM
  #125
sry110's Avatar
sry110
^ Nope, sorry. No first-hand experience. Purely speculating, I will guess that you would have to cut out two rectangular notches in the front "lip" of the diffuser (under the car) to allow clearance for the diagonally-oriented rear mufflers or the pipes leading up to them in the TDX2 system. I believe somewhere on this thread there was someone running the Injen true-dual system which has a similar layout to the MD TDX2, and they had to make two cutouts for clearance.
It's not a big deal IMO, just start with small cuts and keep enlarging until you have clearance. Structurally I do not think you will really compromise the integrity of the diffuser.
Old Aug 21, 2013 | 04:51 PM
  #126
isy_nismo's Avatar
isy_nismo
Anyone have the Amuse R1 with TS diffuser?
Old Aug 22, 2013 | 09:07 PM
  #127
ChriZTT's Avatar
ChriZTT
I'm curious about the functionality of this diffuser when paired with a non OE styled exhaust i.e., an exhaust like the Motordyne TDX, or HKS. The stock (OE) exhaust canister at the rear was, to my knowledge, designed as a diffuser to efficiently move air from underneath the car. When replaced with an exhaust design resembling the TDX or HKS systems the empty space that was once filled by the large stock canister now acts like a pocket that traps air creating a parachute-like effect. Any thoughts on this or whether this diffuser aids in remedying this potential issue for those concerned?
Old Aug 23, 2013 | 03:12 PM
  #128
DerekGreen86's Avatar
DerekGreen86
I am considering this for my Z, does anyone know if these diffusers fit a Invidia N1 exhaust without modification?
Old Aug 23, 2013 | 07:29 PM
  #129
sry110's Avatar
sry110
It might actually interfere with the mufflers themselves....they look pretty large in diameter.
Old Aug 23, 2013 | 08:34 PM
  #130
terrasmak's Avatar
Might try one out soon, my friend has one I can buy if I want it. Now to see if it fits over the Motordyne shockwave V1 and Gamma. Also how hard it will be to swap exhaust at the track.
Old Aug 23, 2013 | 10:12 PM
  #131
DerekGreen86
Thats my worry, I haven't been able to find anyone with the same combination
Old Dec 5, 2013 | 05:35 AM
  #132
dbiz's Avatar
dbiz
will it clear the tomei expreme single without cutting?
Old Dec 10, 2013 | 03:55 AM
  #133
NOLAGG's Avatar
NOLAGG
I would also like to know this since I have the Megan single and is pretty much the same layout as this .
Old Dec 10, 2013 | 11:53 AM
  #134
DrummerGirl's Avatar
DrummerGirl
On the first page someone said it'll fit the n1 exhaust with minor dremeling.
Old Dec 10, 2013 | 11:59 AM
  #135
bender's Avatar
bender
It's not. The Tomei is smaller.
You'd be looking for the fitment of an Agency Power exhaust since they share the exact same dimensions. Bad news, it doesn't fit.
Old Dec 11, 2013 | 11:41 AM
  #136
NOLAGG's Avatar
NOLAGG
That's what I meant , sorry . I mean I fig it wouldn't fit with out modification but my question is , how butchered will it be in the end if I say did try to fit it ?
Old Dec 11, 2013 | 01:35 PM
  #137
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Anyone scrape more with this thing on? Rear of course
Old Dec 11, 2013 | 02:56 PM
  #138
sry110's Avatar
sry110
I have not yet. Old pic showing my ride height (and diffuser installed) for reference. Tires are 245/35/19 f and 275/35/19 rear, with slightly less than 1 "finger" gap tire to fender front and rear:
Old Dec 11, 2013 | 04:11 PM
  #139
taryon's Avatar
taryon
I do a bit actually - but might just be because of my sh*tty driving
and bad driveways
Old Dec 12, 2013 | 04:24 AM
  #140
2004Black350z
Exhaust Whore
Thanks guys for the post. I'm pretty low. I was contemplating a v3 front bumper and one of these for the rear but sketched for clearance
