NEW Gauge Pod for the Z!!!
Old Feb 18, 2012 | 07:46 AM
e30cabrio's Avatar
e30cabrio
That is very cool.
I'd like to put them in back so I can use some of the cubby, I have a subwoofer control in the upper right corner I wold like to keep there, also I put them high up so I can get the rubber "mat" back in.
I can send you the cubby and gauges if that would help.
Thanks!
Old Feb 18, 2012 | 07:50 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
So what you are looking for really is a finishing plate to go in the back and to not relocate the gauges to the front?
Old Feb 18, 2012 | 08:31 AM
e30cabrio's Avatar
e30cabrio
Yessir!
Old Feb 18, 2012 | 09:51 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Hot off the CNC. I know it doesnt help you but it just shows what is doable.
Would you want the finisher plate to be flush with the gauge faces or just something to sure up the mounting plate?
It is a tad to tall for the auto retract to be smooth so I will shorten it.
Old Feb 21, 2012 | 12:52 PM
e30cabrio's Avatar
e30cabrio
Looks great.
5 3/4 x 3 1/2 are the inside measurements.
I just looked. There is very little space behind there so I'd need this inside at least 1/2".
Thanks!
Old Feb 21, 2012 | 05:57 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have a navigation box from an 04 i believe. The dimensions I measured were 3.5x5.8 at the very bottom. If the plat is to be elevated then the dimensions would change slightly since the main opening is about 6.11x3.63.
Are you wanting .5" between the plate and back of the box or between the plate and the face of the box?
White is the box. See the dimensions in cyan.
Old Feb 21, 2012 | 06:02 PM
e30cabrio's Avatar
e30cabrio
I need to have .5" in back to be able to get it back in.
Thanks!
Old Feb 21, 2012 | 06:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
so you want the green line?
Old Feb 21, 2012 | 06:21 PM
e30cabrio's Avatar
e30cabrio
No, sorry. I need it to fully fill the cubby, I just need a way to fasten it so it can be .5" inside the back to allow me to fit it in. There is virtually no room behind there.
Old Feb 22, 2012 | 03:03 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I am lost.
Are you saying that you want the plate to be flush with the cubby but have .5" flanges on the sides/top/bottom so that you can put a screw though the box to mount the plate?
The pic I posted is not the face on view but a top view of the cubby to get an idea of the taper. Its not a perfect box.
Old Feb 22, 2012 | 04:03 AM
e30cabrio's Avatar
e30cabrio
Yes, exactly,
I thought the diagram was looking into the cubby. Sorry.
Old Feb 22, 2012 | 07:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I will cad this up when I get home. Maybe CNC it out of some poplar that I have laying around.
Old Feb 22, 2012 | 07:17 AM
e30cabrio's Avatar
e30cabrio
Sounds great. Let me know what you need and pm me your paypal and I'll send $.
Thanks, I really appreciate it!
Old Feb 22, 2012 | 08:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Do you want me to make it to your dimensions or the ones I measured on my nav box? I would think your dimensions would be best.
Taper the sides or is your box a true box?
The poplar I use is .75". That leaves room for .5" in tabs and .25" face thickness.
Holes...do you want holes drilled in it?
What is your gauge face diameter? Need to know for clearance reasons.
Old Feb 22, 2012 | 08:26 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
1st stab.
I used the gauge dimension of what I have in my cluster.
The inner circles are the ones for the gauge (52mm) while the outer circles are the ones for the face clearance.
Old Feb 22, 2012 | 08:31 AM
e30cabrio's Avatar
e30cabrio
Looks great. I am not home so can't measure them now. I can make adjustments if I need more space.
I really appreciate your efforts!
Thanks.
Old Feb 22, 2012 | 03:03 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
headed to cnc
Old Feb 22, 2012 | 03:07 PM
  #38
e30cabrio's Avatar
e30cabrio
Amazing!
Thanks!
Old Feb 22, 2012 | 04:24 PM
  #39
Cux350z's Avatar
Cux350z
hatersgonnahate
Got some chip out at the edges as I suspected would happen. I tapered the sides to match the box taper.
This was a rough cut with maximum depth per cut and not finishing work done by the cnc. I will set it up again to do it smoother.
The gauges will provide some of the rigidity for the plate near the edges. The 350z box just is too small to fit 3 52mm gauges in it without some extra material.
Old Feb 22, 2012 | 04:28 PM
  #40
e30cabrio's Avatar
e30cabrio
Looks great!
Thanks!
