Removing Rear Fenders.
Old May 10, 2008 | 11:42 AM
saberphx's Avatar
saberphx
Default Removing Rear Fenders.
Anyone know where I can find a step by step for this? I couldn't find anything with the search feature.
Need to remove my rear fenders to make wider fenders out of fiberglass. I imagine you have to cut the inner seam in the wheel well.
Or is it too much of a b*tch to do and recommend making over-flares. Is the do-luck rear fender a piece which goes over the fender or replaces it?
Any help or tips is much appreciated!!
Old May 10, 2008 | 12:48 PM
Carbon-Z's Avatar
Carbon-Z
Sleeps in 350Z
Umm you can't remove the rear fenders unless you plan to cut the welds all along the bottom, trunk and roof and door area.
It's welded all around.
Old May 10, 2008 | 12:55 PM
350ZTheStandard's Avatar
350ZTheStandard
The kits usually go on over the existing body panels, or you could do brain salad surgery.
Old May 10, 2008 | 01:40 PM
saberphx's Avatar
saberphx
Thanks for the replies, I thought removing it would be a few bolts and the bottom inner seam weld but I guess not. I thought it was possible because the do-luck rear fenders look seam-less and as if they replace the rears. Guess its just an add on and thats what I will be doing.
Thanks again for the replies.
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
