Clear reflector gap???
Old Jun 2, 2008 | 09:30 AM
haeshik's Avatar
haeshik
Default Clear reflector gap???
i just installed my 06 clear reflectors (ordered from zstore) and on both sides their are gaps that i didn't have before with stock reflectors. i know i know this thread is fail cause im too lazy to snap some shots. its hardly noticeable unless you look for the gaps but im really **** about the smallest detail. is this normal??? i checked other pics of members with clear install and it seems like they have no gap at all.
Old Jun 2, 2008 | 09:33 AM
Al Kapwned's Avatar
Al Kapwned
When I installed my 06+ clear reflectors they fit perfectly. There are some tabs I believe that have to snap into the bumper if I remember right. This may be causing it to push away from the bumper a little. It is most likely how you installed them. I hope this helps.
Old Jun 2, 2008 | 09:36 AM
haeshik's Avatar
haeshik
thanks for the quick response, i will most likely install again to see if i did anything wrong
Old Jun 2, 2008 | 09:41 AM
07rdsterGT's Avatar
07rdsterGT
I don't know if the 06 is the same as my 07, but you may have installed them on the wrong sides. Are your gaps at the top and bottom of the reflectors?
Edit: Yes they are 06+ I see.
Old Jun 2, 2008 | 09:43 AM
haeshik's Avatar
haeshik
actually yes. i have small gaps on top and more noticeable gaps on bottom.
Old Jun 2, 2008 | 09:48 AM
Al Kapwned's Avatar
Al Kapwned
I didnt think they would fit if you tried to install the wrong reflector on the wrong side. I could be wrong though. When you are redoing/looking at your install just look for the markings on the back of the reflectors. It should be labeled on the back of them which side they go on. There should be a big RH or LH on the back of them. Good Luck. Post your results.
Old Jun 2, 2008 | 10:07 AM
07rdsterGT's Avatar
07rdsterGT
Yeah, they fit, but there is a slight difference in the angle on the top and bottom of the reflector. Switch sides man!
Edit: i also looked before I did my install and there were no markings that indicated "a" or "b" / left or right.
I just compared the clear lens to the amber and noticed right off the bat that the bottom of the reflector should be angled slightly downwards. NOT upwards.
Old Jun 2, 2008 | 10:58 AM
sintaxeror's Avatar
sintaxeror
Ive got clears sitting in my room right now and I believe they say "R" on one and "L" on the other... not 100% on that because I am at work right now but I am pretty sure.
Old Jun 2, 2008 | 01:17 PM
haeshik's Avatar
haeshik
you cannot switch sides!!! the holes do not line up if you put it on wrong side. i had it right the first time but was just curious cause i had a lil gap. it was me just being a perfectionist. i took my car to precision z cause its near my house and the whole crew checked it out for me and said it was installed correctly. the gap is not really noticeable unless you look for it so im pretty happy still. Thanks for the help guys
Old Jun 3, 2008 | 03:23 AM
07rdsterGT's Avatar
07rdsterGT
Right on. I didn't have a gap. Did you buy the JDM corners or after market? I see you got them at the z store, but their site is a little convoluted (you can search and find items that you can't find browsing by category)
Old Jun 3, 2008 | 04:46 AM
sintaxeror's Avatar
sintaxeror
I went out and looked and there is a tiny gap even with my stock ones...
Old Jun 3, 2008 | 05:15 AM
07rdsterGT's Avatar
07rdsterGT
Oh, LOL! I didn't consider that a gap. I mean, if your putting it under a microscope!
Old Jun 3, 2008 | 05:26 AM
haeshik's Avatar
haeshik
^hahah yeah like i said i was being a perfectionist. thanks for all the input guys
35reilly
Sep 28, 2015 07:42 AM
