"bumper tuck" pic request!!!
Old Mar 29, 2009 | 06:37 PM
  #221
BLUby_U's Avatar
BLUby_U
^ i need a towel, wow
Old Mar 29, 2009 | 06:54 PM
  #222
Zenica's Avatar
Zenica
Originally Posted by gambino
I just did mine and it was super easy!
What exhaust is this, one of the nicest setups I've seen.
Old Mar 29, 2009 | 09:18 PM
  #223
tonyrd1's Avatar
tonyrd1
HKS
Old Mar 29, 2009 | 10:05 PM
  #224
ADMAN's Avatar
ADMAN
Originally Posted by tonyrd1
HKS
What are you doing outside the Hot Asian women thread - post pics ***NWS*** thread???
Old Mar 29, 2009 | 10:37 PM
  #225
Escobar's Avatar
Escobar
Originally Posted by Rickdogg
Here's mine before I send it in for paint with molded side rear pieces I tucked the center and cut out the side a bit as well for a different look from the typical tuck only.
that looks awesome Rick...
Old Mar 30, 2009 | 04:38 AM
  #226
got556's Avatar
got556
Agreed....simply awesome Rick.
Here's some shitty shots of mine....car is in the rebuilding process from a slight wreck lol...and yes I have new tires on the way for the rears...i bought the TE's w/ the tires already mounted and am not driving on them.
Part of the carnage from said wreck....along w/ 3 fubar'd wheels, one broken spindle, one broken ABS sensor, one broke compression rod, a bent fender, one bent rear trailing rod, one bent SPC camber arm, a completely missing half Stillen Splitter, and lots of scrapes and bruises all over the front bumper and sideskirts....what happens when you smack a curb at 30 mph and do a 540 while on the curb.....
Old Mar 30, 2009 | 09:51 AM
  #227
ADMAN's Avatar
ADMAN
OUCH!!!
Old Mar 30, 2009 | 10:24 AM
  #228
Rickdogg's Avatar
Rickdogg
Out of hiatus
Thanks guys!
Old Mar 30, 2009 | 10:25 AM
  #229
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by ADMAN
OUCH!!!
Luckily you didn't have Rotas.
Old Mar 30, 2009 | 11:35 AM
  #230
tonyrd1's Avatar
tonyrd1
hahahaaha, i will post more pictures tonight
Old Mar 30, 2009 | 11:46 AM
  #231
BLUby_U's Avatar
BLUby_U
lmao
Old Mar 30, 2009 | 01:20 PM
  #232
got556's Avatar
got556
^Troof lol
Old Apr 7, 2009 | 12:33 PM
  #233
ish06FairladyZ's Avatar
ish06FairladyZ
Originally Posted by black06z
Its a pretty easy mod, as long as your not on a uphill slope. All I did was unscrew the white plastic pieces on each side, and screwed the bottom hole to the top. I didn't even touch the middle of the bumper. That tiny sag makes it look more natural.
^^^+1 I did the exact same thing and it looks awesome, no need to drill or anything... just my .02
Old Apr 7, 2009 | 01:01 PM
  #234
Jon70ProofZ's Avatar
Jon70ProofZ
i tried that but one of the tabs had a slit in it and it ripped all the way across while going down the interstate i guess
Old Apr 7, 2009 | 02:10 PM
  #235
ADMAN's Avatar
ADMAN
Yeah, I orginally tried new tabs nade from ABS, glued to the underside of the bumper.
After they broke, I drilled the b!tch and went all in. Oh, well...
Old Apr 7, 2009 | 02:23 PM
  #236
350ZnFuture's Avatar
350ZnFuture
I tried to push my bumper up and I notice two black tabs on each side what did you guys do with those
Old Apr 7, 2009 | 03:31 PM
  #237
ADMAN's Avatar
ADMAN
The tabs are what people use to "tuck" the sides with. But, the middle still sags.
If you are talking about the hard plastic pieces, I removed mine and threw them away.
I then cut off the tabs too. Check earlier posts for details...
Old Apr 7, 2009 | 05:40 PM
  #238
350ZnFuture
thats a pic of the tab?? do I have to drill holes to use tabs? what size nut is that
Old Apr 7, 2009 | 10:11 PM
  #239
ADMAN's Avatar
ADMAN
Check here for all the info you need:
https://my350z.com/forum/exterior-an...c-request.html
Old May 8, 2009 | 06:21 PM
  #240
User 42426's Avatar
User 42426
Does anyone have a pic of the bumper tuck done with zip ties?
