front reflectors installation
Old Jul 2, 2008 | 05:00 AM
cbr900son's Avatar
cbr900son
I hadf a air compressor so i jacked the car up. Took off wheel. Undid the 2 screw hold wheel well liner at the bottom corner. Then undid 3 screws holding the underliner and wheellines togther. Pull edge back and reach up there with a screw driver. About same amount of work but another method.
Old Jul 2, 2008 | 05:09 AM
Beka Z's Avatar
Beka Z
I'm lucky I am a girl and have skinny arms, i just drove onto two rhino ramps then undid the front of the under panel and stuck my arm in between that and the wheel well. Was done in about 10- 20 minutes.
Old Jul 2, 2008 | 05:24 AM
PerfZ's Avatar
PerfZ
Originally Posted by t1m1t
You can install without taking off the front bumper, but its A LOT easier to just take it off
1. Lift the Z
2. Take off front bumper (bolts, screws, clips)
3. Unscrew original reflectors
4. Screw on new reflectors
5. Put front bumper back on (bolts, screws, clips)
6. SLOWLY drop the Z
Took me about 10-15 minutes total.
Good luck
I'll agree with removing the bumper, but if you did that entire procedure in 10-15 minutes, you should be on a nascar pit crew. Just did mine last weekend and 30-45 minutes is more like it. Not that it is a big deal. Oh, and why would you lift the car? Two screws on each side of the bottom have plenty of room to remove with a short screwdriver, unless you are really lowered.
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
