Interior Touch Up Paint
Old Nov 30, 2008 | 08:56 PM
ekidd's Avatar
ekidd
I just took my center console part out and painted it flat black. Looks oem and matches perfectly.
Old Oct 5, 2010 | 06:19 AM
dcains's Avatar
dcains
http://www.summitracing.com/parts/SHW-FB105/?rtype=10
This is available at many auto parts stores, and I find it to be a perfect match in my '08. I've used it with a fine sable artist's brush for touching up scratches, and completely resprayed the interior door handles with it. After ~8 months, the door handles still have no scratches or visible wear. But, the door handles must be completely striped first, because this spray coating will craze the original finish. I used 6 thin coats, and wet-sanded between each one. I don't know if it does the same thing with the dash panels, but using it for scratch touch-up works fine.
Old Sep 19, 2024 | 03:23 PM
Dink's Avatar
Dink
Default Compartment Door on Dash
Originally Posted by Waiz
Alright gents, I found something on another site and I tried it today and it worked quite well.
Its a water based non-toxic paint that you can mix with water to match the interior colors. The paint is called Delta Ceramcoat.
http://www.deltacreative.com/pcid/16/Default.aspx
I picked it up at JoAnn's with the brushes for about $6.
I started the process by diluted the paint with 60% water and spread the paint on the surface with a fine brush.
I then pat dried it with a paper towel to get a similar texture as the dash and the footwells, and it came out pretty nice.
The paint is cool because its so easy to work with when its wet and you can still remove it even if you make mistakes. Anyone who has ever used the Nissan OEM touch-up paint can attest to how much of PIA that is to work with.
Good luck!!
Previous owner had some kind of phone holder on the dash. When they removed, it left glue spots. Tried to clean, but just made it worse. I followed your recommendation and used a matte black hobby paint diluted with water. Worked like a charm. 2 coats and the compartment door looks brand new and perfectly matches rest of dash. THANKS!
Old Nov 7, 2025 | 10:55 PM
Lucky736's Avatar
Lucky736
Anyone have a pic of their Delta Creative Bottle they can post? Links are long dead.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Cashwin
Oct 1, 2015 06:36 AM
