What to use?
Old Jul 20, 2008 | 05:15 PM
racerfreakxxx's Avatar
racerfreakxxx
Default What to use?
I am gonna be cutting a hole in my front bumper for an evo-r air duct... what do you guys reccomend using to cut hole in the bumper?
Old Jul 20, 2008 | 05:21 PM
keithhofmann's Avatar
keithhofmann
i reccomend not putting a hole in your front bumper
Old Jul 20, 2008 | 05:37 PM
eltness350's Avatar
eltness350
The Untouchable
lol...a dremel will work fine
Old Jul 20, 2008 | 07:04 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Box cutter. Go very slowly, the bumper cuts like hot butter.
Old Jul 20, 2008 | 07:22 PM
moforeynolds's Avatar
moforeynolds
sheit, an everyday steak knife will cut the front bumper Really, it's soft as hell. I used the blade on my Leatherman.
Old Jul 20, 2008 | 07:33 PM
racerfreakxxx
ok... thanks guys. on the instructions it said use a razor blade but i didn't know if that would work or not
Old Jul 20, 2008 | 07:37 PM
matix101vz's Avatar
matix101vz
i just did this 2 days ago, i used a utility knife, works like a charm
Old Jul 21, 2008 | 12:01 AM
blktrack350's Avatar
blktrack350
box cutter works really well
Old Jul 21, 2008 | 12:57 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Using a handheld knife will take forever. Plus, your cuts won't be as nice as it could be. On my messed up bumper I had, I used a box cutter blade and it wasn't that fun.
If you have access to a Dremel (wired with at least 20,000 rpm speed), it would make things much much easier and faster for you. Make sure you use the proper attachment tool (high speed cutter). I said wired because battery runs out faster than you think and 10,000 is too damn slow so higher the speed the better.
Old Jul 22, 2008 | 12:18 PM
mjcos77's Avatar
mjcos77
Box cutter worked fine, but I heated the blade up in between cuts, made it much easier.
Old Jul 22, 2008 | 12:32 PM
zulator03's Avatar
zulator03
fred is a nub
