Rear Fog Light [ EDM / JDM ]
Old Sep 23, 2008 | 07:18 PM
J_STATUS's Avatar
J_STATUS
Default Rear Fog Light [ EDM / JDM ]
I'm just curious where to get the rear foglight (left side, it replaced the back up light) its definitely EDM but is it also JDM ?
Old Sep 23, 2008 | 11:46 PM
asianracerchick's Avatar
asianracerchick
any pics of how it looks like?
Old Sep 24, 2008 | 01:05 AM
3FIDDYZED's Avatar
3FIDDYZED
Do you mean this?
I can get for you in the UK but the fittings may be a little differnet... Would happily swap mine as I wat a more even look at the back as there is only a fog on one side..
Old Sep 24, 2008 | 01:47 AM
Q8-350's Avatar
Q8-350
It's the fog by the signal light, driver's side
I'll be more than happy to get you one from here, but does your Z comes equipped with the switch for it (it's integrated with the turning signal's column)
Old Sep 24, 2008 | 01:56 AM
Z04's Avatar
Z04
the US models do not have this switch so he is doing this purely for looks
Old Sep 24, 2008 | 01:58 AM
Q8-350's Avatar
Q8-350
Well, he can always keep a separate switch to operate the light and make it functional
Old Sep 24, 2008 | 06:50 AM
Kwame's Avatar
Kwame
I got my complete kit from here:
http://www.thezstore.com/page/TZS/PROD/350z04b/33-1360
comes with the switch and instructions.
Old Sep 24, 2008 | 05:06 PM
J_STATUS's Avatar
J_STATUS
so is it jdm also ? or only edm?..... and why some are on the left and some on the right side? does it follow the driver left or right?
Old Sep 24, 2008 | 05:45 PM
Kwame's Avatar
Kwame
The standard is for it to be on the driver's side.
"Most jurisdictions permit rear fog lamps to be installed either singly or in pairs. If a single rear fog is fitted, most jurisdictions require it to be located at or to the driver's side of the vehicle's centerline — whichever side is the prevailing driver's side in the country in which the vehicle is registered. This is to maximize the sight line of following drivers to the rear fog lamp. If two rear fog lamps are fitted, they must be symmetrical with respect to the vehicle's centerline."
Old Sep 24, 2008 | 05:49 PM
Kwame's Avatar
Kwame
It is both "EDM" and "JDM" so to speak. Any country adhering to ECE Regulation 48 must be equipped with a rear fog light.
http://en.wikipedia.org/wiki/ECE_Regulations
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
