Seibon VSII Carbon Fiber Hood cannot be close
Old Oct 15, 2008 | 06:47 PM
kof0127's Avatar
kof0127
Default Seibon VSII Carbon Fiber Hood cannot be close
I just purchase a Seibon VSII style carbon fiber hood, but it doesn't fit. what can I do to fix it? what is the commom problems, can anyone tell me?
Old Oct 19, 2008 | 10:42 AM
trefidyZ's Avatar
trefidyZ
Haha mine doesnt fit either i just posted a thread about mine. The only solution that i can think of is to put in some hood pins.
Old Oct 19, 2008 | 08:39 PM
Mike@Blackline's Avatar
Mike@Blackline
interesting that seibon, being a big player in CF and mad expensive would make something that doesnt fit 100%....lame
Old Oct 19, 2008 | 09:22 PM
samjcg's Avatar
samjcg
talk to the company you bought it from. or if it was 1 of the vendors here they should be able to take care of you. you bought it from them, they deserve to give you 100% satisfaction.
Old Oct 19, 2008 | 09:43 PM
Spork's Avatar
Spork
Isn't a common problem the fact that the hood hits the strut bar?
Old Oct 19, 2008 | 09:46 PM
Darwizel's Avatar
Darwizel
I had to adjust my hood latch a lil higher to be able to fit my seibon hood. Im actually selling it and its 2 months old so its almost brand new. SEIBON TS HOOD ON SALE! WHO EVER'S INTERESTED LET ME KNOW SO WE CAN NEGOTIATE.
Old Oct 19, 2008 | 10:26 PM
Spork's Avatar
Spork
WTF
Old Oct 19, 2008 | 10:42 PM
Nexx's Avatar
Nexx
Originally Posted by Kirk Lazarus
WTF
lmao, +1
Old Oct 20, 2008 | 12:45 AM
Darwizel's Avatar
Darwizel
WTF
I guess this is not the proper time to be selling my seibon hood when some people's having problems with it . My bad about that , but i personally never had that much problem installing it. All it took was some washers and some adjustments and it alligns and closes to lock with no problem . Im simply trying to get rid of my seibon for an asuka hood.
Old Oct 20, 2008 | 05:52 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Mike,
If you think $500 is "mad" expensive for a carbon fiber hood, you don't know composites or the cost of carbon.
To the OP, If you haven't already adjust your latch catch. Not the latch on the hood, but the catcher on the car. If that fails, try adding shims to the back hinges. Sometimes, the hoods will hit the strut bar, including the OEM stru bar.
If that doesn't work, bring it to a body shop who can dremel the hinge holes as needed or add hood pins.
Jim
Old Oct 20, 2008 | 05:55 AM
JAM3Z's Avatar
JAM3Z
Phenom
+1 to that. Of all the players in the CF hood market, Seibon is consistently very affordable. Companies like Top Secret, Do-Luck, etc have hoods that retail for over $1500.
Old Nov 1, 2008 | 06:45 AM
Cosborne's Avatar
Cosborne
Your carbon fiber hood should fit perfectly. Check to make sure there aren't any rubber bumpers under the hood keeping it from shutting. A lot of manufacturers install these to make sure the hood doesn't vibrate or slam into the body when you shut it. Also another common cause is an aftermarket strut bar hitting the bottom of the carbon fiber hood. You can put playdough on the strut bar to determine if it is hitting. Also, this is kind of common sense but make sure you have moved your striker receiver all the way up. It should only be two or three bolts.
If none of this works, call the company you bought it through. They will be able to get a replacement for you for free. That's what we do anyway.
Old Nov 1, 2008 | 08:18 AM
str8dum1's Avatar
str8dum1
^^ no way will they replace for free. EVERY carbon hood maker explicitly says you bought it, its yours. tough luck and take it to a professional body shop.
just ask showstoppers. they'd never replace/refund a non 100% fitment hood. They'd tell you exactly what he said above.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
