Question about 08 Center console.
Old Oct 25, 2008 | 11:17 PM
cld622's Avatar
cld622
Question Question about 08 Center console.
Does anyone know if a center console from an 08 350Z fit on a 03 350Z? I would like to swap mine out so that I can have the the cup holders that are under the slide back compartment.
Thanks for any help.
Old Oct 26, 2008 | 05:09 AM
matix101vz's Avatar
matix101vz
if u find out let me lknow bc i want to do this to
Old Oct 26, 2008 | 06:26 AM
Kiriller's Avatar
Kiriller
im 99% sure you can. Nothing has changed, the fitment is till the same, just the actual console is different. go to your local nissan and order up your brand new spanking console
Old Oct 26, 2008 | 06:54 AM
dkmura's Avatar
dkmura
General & DIY Moderator
You'd be wrong. We did this for the Nissan Sport Magazine Project 350Z car a few issues back and had to change out both the center console AND the upper waterfall IP. The '03-05 IPs are different from the '06-08 models and will not fit together unless you purchase and retrofit both pieces.
You'll also need to rewire the emergency flasher as it gets relocated higher in the waterfall area. It doesn't have enough slack in the wires to make the connection function. The small lights in the cupholder of the '06-08 center console also won't work unless you locate and rewire a new power supply.
David Muramoto
Editor-in-chief
Old Oct 26, 2008 | 07:12 AM
matix101vz's Avatar
matix101vz
that sucks. i hate my 03 console
Old Oct 27, 2008 | 07:43 AM
cld622's Avatar
cld622
Thanks David for your help and I will look at getting the console and the waterfall.
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
