Removing driver's door switch panel
Old Nov 13, 2008 | 05:15 AM
MoJ's Avatar
MoJ
Default Removing driver's door switch panel
I posted the question in another thread a few days ago but didn't get any replies. How do I remove the switch panel finisher trim pictured below? I ordered a new one because the old was scratched.
I appreciate the help.
Old Nov 13, 2008 | 05:55 AM
Z04's Avatar
Z04
what the hell did you do to that?
also, there should be a circular bolt cover at the bottom of the middle piece (under what looks like foam). you pop that cover and unscrew it. the vinyl piece next to it just pops right off. once that first screw/bolt is out, the rest is pretty much straight forward.
Old Nov 13, 2008 | 06:04 AM
spinviper's Avatar
spinviper
How much is the new one ? Mine is exactly like that too ............
Old Nov 13, 2008 | 03:51 PM
MoJ's Avatar
MoJ
Thanks for the info!
That pic isn't from my car... mine is actually very minor compared to the one pictured. There's a lengthy thread about the scratches in that area. The area scratches very easily, especially if you wear a wedding ring.
https://my350z.com/forum/exterior-in...scratches.html
The piece was $64.22 + shipping from courtesyparts.com. Part # 80961-Z33006 for a 2006 Z.
Old Nov 13, 2008 | 05:07 PM
sam2944's Avatar
sam2944
This car belongs to scissors-hand?
Old Nov 14, 2008 | 05:00 PM
JonnyRod's Avatar
JonnyRod
ive got an extra driver's door switch panel if anyones looking...came off an 03'
Old Nov 16, 2008 | 09:18 AM
tonester1011's Avatar
tonester1011
CF God
no screws...it just pops right off
Old Nov 16, 2008 | 09:51 AM
Z04's Avatar
Z04
no, that part does not "pop right off". the vinyl padded part next to it does but the switches do not
Old Nov 16, 2008 | 11:06 AM
jray8's Avatar
jray8
<img src=http://www.ugo.com/movies/burton-depp/images/edward-scissorhands.jpg>
Old Nov 16, 2008 | 11:14 AM
tonester1011
CF God
u sure?? cuz last i remember it does...i could be wrong and im sorry if i am
Old Nov 16, 2008 | 03:51 PM
MoJ's Avatar
MoJ
Are you sure? I don't see any screws or screw covers on mine. I guess maybe when the new panel arrives I might be able to figure out what is holding the old one on...
Old Nov 17, 2008 | 08:34 AM
tonester1011
CF God
im just about 100% sure...u pull the piece from the end towards the back of the car...there is a metal piece that keep it wedged in...i really dont think their are any screws...i looked at mine yesterday when i got in the car and there arent any.
Old Nov 17, 2008 | 11:51 AM
Greedy4nismo's Avatar
Greedy4nismo
maybe it changed for the 06+ models that have the insert of leather on the door? for the 03-05, it just pops off.
Old Nov 19, 2008 | 08:04 AM
tonester1011
CF God
it hasnt changed for the 06...i have 06 panels in my 04...they just pop off on the drivers side...pass side u need to remove the door pull first then it just pops off...im positive
Old Nov 19, 2008 | 08:09 AM
tranceformer95's Avatar
tranceformer95
03-05 you need to remove the screw and screw cover. Not sure about the 06+.
Old Nov 26, 2008 | 06:09 PM
MoJ's Avatar
MoJ
Just wanted to add a final verdict to this thread...
I replaced the finisher trim piece tonight --- it just pops off, no screws, not on the '06 interior anyway. I used a small right angle pick and started at the end closest to the padded arm rest. Pull straight up and then work your way toward the front as there are several clips holding it in. Once it's loose you can snap off the switch assemblies. New one snaps back on.
My interior black. The first part I received from Courtesy was grey. After returning it they sent me part # 80961-CF40E which worked perfectly.
Thanks for the help.
Old Nov 27, 2008 | 06:15 AM
tonester1011
CF God
told ya...
Old Nov 27, 2008 | 01:01 PM
2k6-z33's Avatar
2k6-z33
Old Nov 28, 2008 | 05:46 AM
Z04's Avatar
Z04
hmm, now i got to go out and look at mine again, i could have sworn that you had to loosen a screw/bolt to take the whole switch cover out. i knew the padded piece just pops right out.
even this site shows the screw i was talking about (step 2)
http://liljerk.morpheus.net/350Z/front_speakers/
but then again, it could be different in a 06+
Old Apr 4, 2013 | 04:57 PM
BeastiZ's Avatar
BeastiZ
Thank you for the posts. I have the exact same scratches on my armrest and the other plastic parts in the interior. Apparently there was a defect in the paint and it didn't bind correctly. It appears to be in the 06's. Anyway, Im wrapping my parts in 3m vinyl wrap and needed to know how to remove the armrests. thank you
