headlight problem help pls..
Old Jan 6, 2009 | 02:27 PM
BreadTalk's Avatar
BreadTalk
Default headlight problem help pls..
guys i have a 2003 z.. do all models of the Z have ballast in them for the headlight?
the problem is of course the headlights wouldnt light up after a carwash.. there are condensation inside the headlights.. so im pretty much sure water went inside.. so can i say that the ballast is the problem now? or it might be just the bulb? the highbeam and the turning lights work fine..
i would like to take care of this problem by myself..
Old Jan 6, 2009 | 02:37 PM
LaoSiFu's Avatar
LaoSiFu
For the 2003, only the Enthusiast models and up have a ballast because they have HID. If you do have HID, this is what I suggest. It may or may not help. Remove the ballast from the HID, shake off the excessive water, let it dry under the sun and re-install it. As for condensation in your headlight, you might want to open them, clean and seal them.
Here is my DIY on opening up headlight.
https://my350z.com/forum/body-interi...k-housing.html
~Robert
Old Jan 13, 2009 | 09:33 PM
wutafobb's Avatar
wutafobb
Default How can I get 06+ headlight to my 04 Z
What needs to be done to get 06+ headlight to my 04 Z.
my headlight are damage, I want to put 06+ on the Z.
Where can I get them and what modification do I need?
Thanks in advance!
Old Jan 13, 2009 | 09:57 PM
LaoSiFu's Avatar
LaoSiFu
Thanks in advance!
is your car HID equip or not. If it is standard HID, it is all plug and play. No modification require.
~Robert
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
