What combination would work?
Old Jan 12, 2009 | 08:52 PM
luv2bsidewaz's Avatar
luv2bsidewaz
Default What combination would work?
At the moment I have a Seibon CF Ts hood. The fitment is a little off, not that bad at all, but a little off. The problem I am having is that I am running a Motordyne 5/16 Plenum spacer and it is causing rub on the plenum and strut against the inside of my hood. I was thinking of going an 07 oem cf hood. Would this help the rub since it has the "hump" in the hood? Also I am looking into an aftermarket strut bar as well though I know this will cause the rubbing to become worse. Anyone running spacers and aftermarket struts with cf hoods? If so can you tell me the combination of parts? Thanks.
Old Jan 12, 2009 | 09:04 PM
How about a strut bar that fits in front of the plenum instead of over the top?
Old Jan 13, 2009 | 12:58 AM
luv2bsidewaz
What brand would that be so I can look it up? I've heard of them being made for the z but can't remember a brand.
Old Jan 14, 2009 | 11:00 AM
Zeebra's Avatar
Zeebra
Im sure theres tons of members on here including me that have Seibon CF hoods with plenum spacers and stock strut bars and not rubbing.. I would check your hood alignment and strut bar install too.
Old Jan 14, 2009 | 11:05 AM
SweetDreamZ's Avatar
SweetDreamZ
i have the same problem with mine...hell, my TS hood rubbed on my stock strut bar...and nowthat I have the MD spacer and spaced the strut bar, it rubs even worse. you CAN cut the underside of the hood out in strategic places to allow better fitment...if you have the cojones to chop on your hood...
Old Jan 14, 2009 | 11:38 AM
Zeebra's Avatar
Zeebra
dang that sux guys.. I dunno then. The only clearance issues I have is with my nrg hood dampers.
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
