Voltage Meter/Gauge Reading 16volts!!?!!
Old Jan 16, 2009 | 05:53 PM
350ZNME's Avatar
350ZNME
Default Voltage Meter/Gauge Reading 16volts!!?!!
Got in my car this morning and noticed this....
Sorry about crapy cell pic.
Anyone ever seen this before?
Old Jan 16, 2009 | 08:26 PM
Smoothy34's Avatar
Smoothy34
Do you have a multi-meter? If so check the voltage at the battery terminals while it's running...if it matches your gauge the voltage regulator is probably bad. I know when i first start my car it reads almost 16, like 15.5v, but settle down to 14.4 after warm up
Old Jan 19, 2009 | 09:53 PM
EVAlonSo's Avatar
EVAlonSo
Temperature has an effect on voltage. usually on a cold morning during a cold start, you will have high voltage. normal.
Old Jan 20, 2009 | 04:39 AM
350ZNME's Avatar
350ZNME
I cant remember if it was cold out that morning, but that night i realized my right head light was out.
Old Jan 20, 2009 | 05:21 AM
t0mills's Avatar
t0mills
Hmmm, I would definitely check the voltage at the terminals with a multimeter.
Like someone said earlier, it could be a regulator going bad. Overvoltage will cause bulbs (like your headlight) to go out, and sometimes explode.
-Tim
Old Jan 20, 2009 | 05:37 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
are your terminals especially your negative terminal dirty or corroded.
Old Jan 20, 2009 | 07:03 AM
350ZNME's Avatar
350ZNME
No, the terminals are clean that was one of the frist things I checked. Bringin a battery meter home from work tonight to check the voltage also.
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
