++Seibon CF hatch Problem++
Old Feb 2, 2009 | 10:10 PM
GooDy151's Avatar
GooDy151
Default ++Seibon CF hatch Problem++
Hi
I just got my hatch from Seibon and installed it.
I have problem get it close correctly. The gap between edge of the hatch and rear quarter panel is so big. I can put my whole hand in to the gap.
I did adjust the latch as far as I can but seem like it didn't help at all.
I finally had to remove my hatch damper to get the hatch close perfectly because it seem like the CF hatch is really flexible so the damper push it up.
So right now it's look good like it should but I don't have damper on my hatch. I have less function but not that bad.
So I'm trying to ask people who has CF hatch if you guys have the same problem.
I did search and didn't find anything. If my search skill was bad I'm sorry.
thanks for reading
Old Feb 2, 2009 | 10:45 PM
Germanguy's Avatar
Germanguy
im interested too. coz i get soon the same hatch
alex.
Old Feb 3, 2009 | 09:01 AM
GT47R's Avatar
GT47R
+1 here, I'll be receiving mine soon.
Old Feb 3, 2009 | 09:06 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Originally Posted by GooDy151
Hi
thanks for reading
This is a common problem with all carbon fiber hatches. The hatches are considerably lighter then stock, so the stock hatch dampers are too powerful for the new lighter hatch causing it to raise. JT makes some hatch dampers specifically for carbon fiber hatches but are pretty hard to come by instock. This has been a cure for almost everyone who ran into this same problem.
If it really doesn't bother you, you sould be fine with no dampers but it's a pain to open and close.
Old Feb 3, 2009 | 09:32 AM
Jim@Showstoppers
Heres a link
https://my350z.com/forum/vendor-grou...f-hatches.html
Old Feb 3, 2009 | 03:38 PM
ecorona6's Avatar
ecorona6
I had the same problem with my Asuka hatch. I just removed the dampers. Its been that way for a year now. It sucks when you have to put or pull something out since one hand will be tied up holding up the hatch. The other problem is that the hatch does not pop when unclocked. You have to push it up will unlocking.
It's worth it IMO!
Old Feb 4, 2009 | 01:49 AM
XM 1's Avatar
i think Z1 has also some of those "light weight" shocks for sale
Old Feb 4, 2009 | 08:30 AM
GooDy151's Avatar
GooDy151
thanks guys
just to know that I'm not the one who dealing with this is fine.
I thought that I got defect hatch or something.
It worths it IMO too.
Old Feb 4, 2009 | 09:26 AM
Heretic John's Avatar
Heretic John
post pics
Old Feb 5, 2009 | 12:05 AM
GooDy151's Avatar
GooDy151
here ya go
Old Feb 5, 2009 | 07:23 AM
ecorona6's Avatar
ecorona6
The hatch is a good fit. You should consider painting the doors.
Old Feb 5, 2009 | 11:22 AM
Changvi's Avatar
Changvi
+1. Paint the doors and add cf a pillars and roof caps. I would still suggest cf hatch shocks from Z1 to hold your hatch. Works beautifully with mine..
Old Feb 5, 2009 | 02:49 PM
GooDy151's Avatar
GooDy151
If I wanna paint my door I wouldn't by carbon fiber doors. I bought the door because of the look. Weight saving is a plus.
I like the way it is now.
I might go CF all over the car in the future.
thanks for comment.
Old Feb 28, 2009 | 11:05 PM
whitelightnin's Avatar
whitelightnin
Yeah, stock Hatch struts are too powerful for The lightweight Carbon Hatches and will push the Ish out of them. You have to get aftermarket Hatch Struts That are designed to work with the lighter hatch.
Check http://www.z1auto.com/prodmore.asp?m...or&prodid=3412
Old Mar 1, 2009 | 06:56 AM
Simann's Avatar
Simann
thanks for comment.
So you've spent over $5000 on you car from what I can see in the pictures, and yet you still have the stock antenna?
Old Mar 1, 2009 | 10:55 AM
SchismX's Avatar
SchismX
I still have a stock antenna as well. Your point is?
Old Mar 1, 2009 | 03:19 PM
somebody's Avatar
somebody
what is wrong with stock antenna?.........do you like the crappy/short s2000 option????
Old Mar 1, 2009 | 03:38 PM
SuperBlack350z's Avatar
SuperBlack350z
what's wrong with the stock antenna?
Old Mar 1, 2009 | 05:58 PM
Simann's Avatar
Simann
Old Mar 1, 2009 | 06:00 PM
OCMan's Avatar
OCMan
lol...no comment
