Carbon Fiber Vinyl Pattern Wrap Thread
Old Mar 5, 2009 | 09:03 PM
  #141
red_magic2000's Avatar
red_magic2000
This looks way better than any CF part or stick on I've seen Got one question, I do happen to like the glossy look, but don't like how the weave on most carbon fiber parts look, is there any way that once wrapped you can spray the part with something to give it that glossy look? I was thinking maybe some expoxy and then a few clear coats Any bodyshop guys who can maybe answer this question, or if it can even be done?
Old Mar 6, 2009 | 06:36 AM
  #142
zman600's Avatar
zman600
^^ why dont you just get the cf kits??? its going to look the same as the kit if u make it glossy...right? becides suddly differences
Old Mar 6, 2009 | 05:16 PM
  #143
Soni's Avatar
Soni
Old Mar 6, 2009 | 06:04 PM
  #144
oro's Avatar
oro
My guess is probably $600 kit vs $70 dollars + labor.
Old Mar 6, 2009 | 06:26 PM
  #145
somebody's Avatar
somebody
Originally Posted by Blackzizzle
Somebody, would you send that illustration to me as well? I already purchased the material from you, and was wondering about this as well. Thanks!
no worries....I'll post the pics on this thread on Sunday afternoon/night....too "buzzed" to do a photoshop job now.
Soni & I (mostly Soni...he he) spent a few hours trying to figure out how we could do the top section (3 pods).
It will help you guys.
Thanks again for all the positive comments.
Old Mar 6, 2009 | 11:09 PM
  #146
red_magic2000
No doesn't look the same, the wrap looks ALOT better. The CF kits always look crappy at the edges, or the weave near a curve looks all distorted. Really disappointed with the CF kits on the market, they look like ****..The real clean look especially around the edges is what attracted me to this wrap. So is there anyway to get it looking glossy?
Old Mar 7, 2009 | 08:46 AM
  #147
nismored's Avatar
nismored
Im sure a good brand of clear coat, some sanding and light coating would get you the look you want to achieve. Try to wrap a small piece or cut a small square and spray 3 or 4 light coats and see how it affects the material.
Old Mar 7, 2009 | 06:56 PM
  #148
Parker01's Avatar
Parker01
FYI all,
I recieved my square yard of material Friday and I'm not disappointed at all. The material looks amazing and has back to it so it looks as if it will be very easy to work with... simply cut and paste! or vice versa. I won't be doing the install until spring so don't expect pics anytime soon hah.
Old Mar 7, 2009 | 07:04 PM
  #149
drewk's Avatar
drewk
I received mine as well. Ive never seen such a material before. I think NASA makes it... space age ****
Old Mar 7, 2009 | 09:27 PM
  #150
*ICE*'s Avatar
*ICE*
group buy??? i been reading the posts from e90post.com and the CF fabric interior looks so SICK!!
http://www.e90post.com/forums/showthread.php?t=203272
Old Mar 8, 2009 | 06:52 AM
  #151
somebody's Avatar
somebody
I'm glad that you guys are happy with the fabric...I'll post some tips & pics for the installation tonight.
Cheers!
Old Mar 8, 2009 | 07:22 AM
  #152
drewk's Avatar
drewk
^ do it bro, I cant afford to **** up the install. Post picks and tips.
Old Mar 8, 2009 | 10:04 AM
  #153
*ICE*'s Avatar
*ICE*
Cheers!
please do!! and did you also wrapped the door handle and other parts of the interior too beside the main dash we already seen on page 1?
Old Mar 8, 2009 | 01:35 PM
  #154
somebody's Avatar
somebody
no....other parts of the interior don't bother me too much. I hated the big, plastic center console. It's good enough for me.
+ PM sent
Old Mar 8, 2009 | 01:53 PM
  #155
somebody's Avatar
somebody
Default Cf fabric application
you need the following items;
~very sharp/new exacto knife: art supply or hardware stores
~3M super77 spray glue: soni posted a pic. in this thread (not sure about how other brands will perform but, super77 is what we used).: art supply or hardware stores
~masking tape: hardware stores
~denatured alcohol: drug stores
~soft cloth
~tools to disassemble/assemble the center console
disassembly
I found this web page.....not sure who but, big thanks.
http://liljerk.morpheus.net/350Z/dash_removal/
Application:
~after disassembly, clean all parts with alcohol.
~cut cloth about 1/2"~3/4" bigger than the part you are covering: it's better to leave a bigger yield...
~once the alcohol is completely dried off / cleaned, apply spray glue.....make sure you cover the whole area
~start from the center & work your way to the edges. DO NOT OVER-STRETCH.
~gently rub the fabric down to the surface. the super77 allows you to make adjustments as you apply....until it dries.
This is the tricky secion....3 pods on the top section:
just take your time, you should be fine.
Let me know if you have any questions.
Old Mar 8, 2009 | 02:11 PM
  #156
drewk's Avatar
drewk
^ are you making sort of like a tent on top of the gauges and the "floor" using the masking tape?
Old Mar 8, 2009 | 02:19 PM
  #157
somebody's Avatar
somebody
i wouldn't say tent.....more like, "wraping" the gauges with masking tape.
the gauges + floor are glued to the back of the cover. i didn't want to break the glued spots. That's why I went through the trouble of wraping these areas before applying the glue, instead of pulling them off completely....hope this helps....
Old Mar 8, 2009 | 02:30 PM
  #158
05Z33's Avatar
05Z33
The pods can be completely removed without breaking them. Even the bottom half of the pods can be removed. You need a heat gun and take your time. I was able to do it using my oven. I just let it heat up to 350 and held the back of the dash away from the top coil about 3-4 inches and it got soft enough to remove. This might make it easier to wrap. You can glue the parts back on when your done.
Old Mar 8, 2009 | 02:32 PM
  #159
somebody's Avatar
somebody
you are a brave man........that makes it a lot eaiser.
Old Mar 8, 2009 | 04:46 PM
  #160
Parker01's Avatar
Parker01
I'm going to remove mine with a heat gun and then try to do the whole "floor" area of the guage pod rather then having than stopping at the edge.
