Wet Sanding
Old Mar 4, 2009 | 12:36 PM
REDLINE LIFE's Avatar
REDLINE LIFE
Default Wet Sanding
Does anyone have any tips on how to wetsand bodykits for paint prep? Thanks!
Old Mar 4, 2009 | 12:42 PM
Z04's Avatar
Z04
yeah, if you have no clue WTF you are doing and have never done it before don't even attempt it.
Old Mar 4, 2009 | 01:30 PM
6speedwonder's Avatar
6speedwonder
...or he can get a mentor and apprentice them for a while?
practice, practice, practice, find someone that knows how to do body work and learn from them, then when you are ready try it on your own kit.
Old Mar 4, 2009 | 01:33 PM
Z04's Avatar
Z04
that is true also, but it sounds like he wants to know how to do it right this very moment and probably does not want to wait that long
Old Mar 4, 2009 | 01:54 PM
6speedwonder
truth...
well this stays true for any car mods, make sure you learn by doing on project cars/workshops before you start working on your own car.
Paint and bodywork is especially difficult, people go to school for years and still do bad work, its a learned skill and you have to be dedicated to learn and perfect it.
No pointers online will really help you learn how to do bodywork, I don't care what anyone says, it can only be learned hands on and through repitition.
Old Mar 4, 2009 | 03:55 PM
35Z's Avatar
35Z
Default Wet Sanding/Color Sanding
Purchase "Paint-U-cation - Color Sanding & Buffing" DVD avaliable from EASTWOOD.com.. It discusses how to eliminate runs/surface defects along with proper sanding/buffing techniques. Typically, purchase some 1500 - 3000 grit wet sandpaper; soak overnight in water; spray the area with water/liquid soap mix, color sand and sand; then buff out to gloss finish; etc,etc.
I presume you are only color sanding the "clear coat".
Old Mar 4, 2009 | 04:30 PM
REDLINE LIFE
Hmm well I'll be working on this with my uncle whos had good experience with some body work so hes helping me with it. I just want to know some tips that I should keep in mind when wet sanding a body kit. He's done work on clearcoats on stock body parts, etc; just not on an aftermarket part... These tips would not only be helping me but him also because hes kinda the brains behind the whole thing. If it was me alone I would not even attempt it, I would just go to a body shop. The tips that I would need involves aftermarket part prepping specifically. Im going to be watching him but do alittle bit at a time, just a learning experience. Some of the parts have dimples, etc that I need some tips on removing. Thanks
- Not the case at all. Please dont assume. Thanks for the input though.
etkms
Jun 19, 2022 06:30 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
jaf1701
Nov 18, 2002 03:52 PM
JJH
Nov 12, 2002 04:26 PM
ganz
Nov 4, 2002 02:48 AM
