2008 350Z hatchback area noise
I initially thought I was getting lots of wind and road noise in the hatchback area. I have since determined that the noise is really all road/tire noise that for some reason(s) seems to be at very high levels and very noticeable in the seating area. I put down some Dynamat Xtreme product throughout the area on Saturday but still have a good bit of noise. The one area that I didn't Dynamat was the wheel wells that protrude into the hatchback area. I'm now wondering if I should be covering the wheel wells with the sound proofing stuff. Thoughts or comments from you folks that may have experienced similar problems would be appreciated.
the z wasnt designed for luxury: it was designed for performance, but yeah i would add it if you want but keep in mind dynomat is going to add alot of weight to your car but good luck
Sound Deadening alone will not block out the road noise you are hearing. Dynomat is mostly for rattles. If you want to block out road noise I would suggest putting in a noise barrier like Second Skins Luxury Liner to block out airborne noise.
Do you have the stock Bridgestone tires... they suck, they give alot of road noise.. I went to Goodyear Eagle F1GS-D3 tires, and i was amazed at the amount of road noise that disappeared, and they grip alot better too.
m_0g
Jun 3, 2021 10:05 AM
