Smoked tails?
Old Apr 25, 2009 | 11:37 PM
_STEVEO_01's Avatar
_STEVEO_01
Originally Posted by ATX350
Glad I could help. I actually had a local painter do mine and he used a candy tint paint mixed with clear coat. It came out really well
Lights look great ATX, doing the same thing to mine... I have seen it done all kinds of different ways, but spraying, wet sanding and clearing it is the best way to go, not to mention... It will give it the cleanest look. Only bad part about this is, it is irreversible if your looking for a different look afterwords. LED tails aren't cheap...
Old Apr 26, 2009 | 02:40 PM
ChrisNelson's Avatar
ChrisNelson
Originally Posted by R350Zz33
heres the ones i have they are vinyl i have a shop do them for $75
I've seen black vinyl before and it is not see through, so do you mean your lights are tinted with automotive tint film, or some type of translucent vinyl?
Old Apr 26, 2009 | 06:03 PM
SharpShooter23's Avatar
SharpShooter23
I have worked with Niteshades for a while now and to prevent from fading you will have to clear them. If you like the flat look that the Niteshades gives before clear coating, buy a Flat clearcoat because clear coat makes it glossy, but please do clear coat them or you will regret it. . You apply the Niteshades in layers, the more layers the darker. But please do remember one thing, Niteshades drys DARKER then it is when wet. Hopefully this helped you.
Old Apr 26, 2009 | 06:37 PM
Volk350's Avatar
Volk350
i have spray tinted rears, got it from a hobby shop, 6 dollars a can, works great! but when in the sun over time it flakes off, and if you do it yourself, it has to be in a good area to paint, not just your garage, i would go with vinlys personally, so you dont have to pay a shop to spray your lights and what not
Old Apr 26, 2009 | 07:07 PM
TJGILROY's Avatar
TJGILROY
i sprayed mine with the hoppy shop tint paint over the weekend....after two coats of tint, i sprayed with clear coat, waited till dry about 3 hours and clear coated again....they look fantastic...i let them sit for about a day and installed them on my car...they blend perfect with my brickyard color(not too dark), i'll post pics tomorrow!
Old Apr 27, 2009 | 06:59 AM
SharpShooter23
Glad it worked out for you. +1 on the pics
Old Apr 27, 2009 | 03:54 PM
TJGILROY's Avatar
TJGILROY
Smile oh yeah...
here they are... hobby shop tint and a couple clear coats and some polish
Attached Thumbnails Smoked tails?-tinttail.jpg   Smoked tails?-tinttail2.jpg   Smoked tails?-tinttail3.jpg
Old Apr 27, 2009 | 03:57 PM
ATX350's Avatar
ATX350
Color looks great but you need to wet sand them down. I'm seeing some orange peel.
Old Apr 27, 2009 | 04:05 PM
Spork's Avatar
Spork
Bluebat overlays
Old Apr 27, 2009 | 04:33 PM
350zDreamZ's Avatar
350zDreamZ
use vinyl and spend the extra money to make sure they come out good
Old Apr 27, 2009 | 05:25 PM
TJGILROY's Avatar
TJGILROY
what grit....and after i sand them...should i just add another clear coat or polish the crap out of it again....?
Old Apr 30, 2009 | 07:38 AM
TJGILROY's Avatar
TJGILROY
what do you recommend to get rid of the orange peel...i've sanded them a bit...i didn't want to mess them up and polished them and they still have a slight orange peel to them??? any suggestion?
Old Apr 30, 2009 | 08:12 AM
ATX350's Avatar
ATX350
I'd start with 1500 then follow up with 3000. You'll need a rotary buffer to polish it out however.
Old Apr 30, 2009 | 09:19 AM
TJGILROY's Avatar
TJGILROY
rotary it is....i'll try it out and see what i get...thanks
Old Apr 30, 2009 | 09:36 AM
pizzato16's Avatar
pizzato16
Glad you found what youre looking for. i did my tint myself with overlays from ebay for lie 20 bucks. it came out nice, not to dark but dark enough to tel theres overlays on. plus havent had any cop trouble since having them, yet.
Old Apr 30, 2009 | 10:47 AM
TJGILROY's Avatar
TJGILROY
how long have you had them pizza? i had some for about a year i got from ebay and they started to fade really bad and when taking them off the sun had literally melted them on and you get tiny little air bubbles in them after awhile, that's why i've spray tinted with clear coat...all i have to do now is get rid of the orange peel like atx says and polish and i should be good to go....we'll see!
Old Apr 30, 2009 | 10:58 AM
pizzato16's Avatar
pizzato16
about 6 months. so far, no bubbles. im hoping mine wont melt to the light. Just want something thats easy to remove incase i get pulled over. i was going to do the headlights when i found out overlays cause the headlight case to get stress cracks from the heat.
Old Apr 30, 2009 | 11:26 AM
  #38
TJGILROY's Avatar
TJGILROY
yeah, it looks like they may have done that to my tails a little, but you never know, that could have happend without them...the last vinyls i had just seemed like they got dull after awhile...at least with the spray, i can sand it whenever and just add another clear coat...good luck with the cops, though, i never got pulled over with my overlays
Old May 4, 2009 | 12:30 AM
  #39
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
Originally Posted by HOOPER350Z
I have bluebatmobile tint on my head and tail lights and it look great. I have not had one problem with it peeling or fading or anything for the 2 years i've had it on.
http://s2.photobucket.com/albums/y42...pe%20Overlays/
Bat
Old May 4, 2009 | 12:52 PM
  #40
TJGILROY's Avatar
TJGILROY
garage kept?
