NEED HELP. Will these rims fit my car?!
Are the wheels even for a Z? I wouldn't even bother because the setup is going to look even worse than stock. The offset in the front and the rear are uneven by a huge margin.......Also, depending on the tire size that comes with the wheels, might potentially confuse the VDC if your car is equipped with it.
http://www.1010tires.com/WheelOffsetCalculator.asp
06' Stock wheel specs:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
Use that. Plug in stock wheel specs and new wheel specs. It will tell you how much further the wheel will stick out, or be sunken in. With a 35mm offset it will look just about the same as stock. The rear wheels offsets are good though, although if you want the flush look you should look for a 19x10.5 +20ish, or 19x9.5 +10...15ish
I'd pass on those wheels.
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
The middle of the rim is 0. lower numbers= larger deep dish look. The higher the number, the more the barrel of the rim is move inwards toward the car. Hope that helps.
Welcome to the world of Off-Sets
go here:
http://rimtuck.com/thumbnails.php?ve...ear+asc&page=7
Page 7 for 350z - GL
go here:
hmm i have no idea how spacers work. but im still a little confused about the 35mm offset. Does that mean the rims are sticking out of the car more or sticking in of the car more? Does anybody have a specific comparison of pictures? =/ im lost still ..
Wheel Offset Definition:
Offset
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
Offset
Zero Offset
Positive
Negative
