Heater is not putting out hot air?
Old May 26, 2009 | 06:09 PM
nosurf2day's Avatar
nosurf2day
Default Heater is not putting out hot air?
I am confused as to why my heater is not putting out hot air.
Symptoms. Well I just replaced my AC compressor because it went out. Unfortuately I have to re replace it because the one I put in was bad as well. Needless to say I am pissed.
I was driving tonight and my windows started to fog up, so I turned on the heater to dry them up. The air came on and was blowing well, but there was no heat coming out. Just regular air temp, not heated temp.
I did have to replace the fuse to the airconditioner because it was blown. I didnt know if I may have blown a fuse to the heater so I checked all my fuses under the hood and nothing is blown.
What am I missing, I am sure this has to be inter related.
Old May 27, 2009 | 06:36 AM
nosurf2day's Avatar
nosurf2day
Someone said something to me about the heater control valve, I want to check it but I dont know where it is, any help?
Old May 27, 2009 | 07:35 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
have you recently replaced/filled the coolant? If there are air bubbles, heat won't work
Old May 27, 2009 | 07:40 AM
Z_Nick_Z's Avatar
Z_Nick_Z
^+1
Check your coolant. I had a problem with now heat, come to find out my coolant was almost empty.
Old May 27, 2009 | 10:41 AM
nosurf2day's Avatar
nosurf2day
Yes, I replaced my ac compressor yesterday and had to drain the coolant, I will check that and see if that fixes the problem.
Old May 27, 2009 | 11:20 AM
nosurf2day's Avatar
nosurf2day
The car was a little low on coolant, i cant seem to get this damn air pocket out of the car, I bleed the rear screw until fluid came out but my high side radiator line still has air in it. The car is not overheating and the air has warmed up a bit, I think this is my problem. I just cant figure out how to get all the air out of the line.
Old May 27, 2009 | 12:05 PM
fairladyboss's Avatar
fairladyboss
you have to put it in a vacuum to get the air out. you need to have the proper A/C tools to pull the air out otherwise you have to take it to someone to get it done
Old May 27, 2009 | 06:37 PM
overZealous1's Avatar
overZealous1
keep heating it up. eventually due to the expansion of the water, it will force the air into the rad where you will fill it and get the air bubble out. expect to do this about 4-5 times.
you will know it is full and no bubbles when you are blowing hot air at idle. don't rely on the stock gauge to tell you anything, it doesn't move from 180-230.
Old May 27, 2009 | 07:00 PM
nosurf2day's Avatar
nosurf2day
back to the car I go
Old May 27, 2009 | 09:03 PM
nosurf2day's Avatar
nosurf2day
little by little it is getting there
Old May 27, 2009 | 11:27 PM
jdmflavor510's Avatar
jdmflavor510
try bleeding the air out with your heater on and press the button with a picture of air circulating inside the cabin to on position. sometimes air gets stuck in the heater core, doing this bleeds the air out completely. at least that's how i bleed air out of my radiator system. just a suggestion, hope this helps in any way.
Old May 28, 2009 | 05:00 AM
nosurf2day's Avatar
nosurf2day
ahh, didnt think of doing that. back to the car
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
