multifunction not working and a lot of light show !!
on
Here is the short story.
I took of stock steering wheel and seats at the same time. And I didn't wait 15mins or anything like that after disconnect battery.
I put after market seats and steering wheel on.
I did expect to have some light show on my dash since I didn't do any bypass all the sensor (air bag , weight sensor etc.)
but now I just put it back to stock.
connect everything back but still have light show up.
+ my horn doesn't work any more + multifunction don't work both cruise control and audio control.
I heard from my friend I need dealer to reset it.
I want to know if he's right.
The air bag light does make sense to me but I don't know why horn and multifunction don't work.
Any idea?
Thanks
and sorry for 3rd grade english.
Any idea?
Thanks
horn doesn't work because the horn isn't grounded properly.
i have no idea what you're talking about.
please correct me if i'm getting your story straight,
you Removed the stock steering wheel, and seats and went with aftermarket parts. Now you would like to go BACK to stock configuration.
you connected all the stock parts back in, but you have alot of warning lights showing up, and you're asking how to remove the warning lights?
multi function / cruise/ audio is all in the connection harness. make sure that plug is correctly in place. probably why your horn isnt working. basically all the wiring for the stock steering wheel is not connected. check to see if the combination switch and spiral cable (its the device that has your blinkers and a white-ish plastic box) is connected correctly.
there is an airbag reset procedure you can do with the key ignition, just search on this forum and you will find it. search for "Airbag Reset" . i wrote one up a long time ago.
i would say remove your stock steering wheel and re-check the harness/cabling connections you did.
