06+ parking light bulb size?
Old Jul 22, 2009 | 07:40 PM
tw8715's Avatar
tw8715
Default 06+ parking light bulb size?
trying to replace with LED's
does anyone know what bulb size i should be searching for?
thanks!
Old Jul 22, 2009 | 09:12 PM
NISMO355's Avatar
NISMO355
The bulb size is 168....look here http://autolumination.com/ for your leds.
Old Jul 23, 2009 | 01:00 AM
tw8715's Avatar
tw8715
so its just 1 led bulb?
there seem to be a ray of leds? is that just the affect it is showing?
thanks
Old Jul 23, 2009 | 01:29 PM
tw8715's Avatar
tw8715
bump!
so i juat get the wedge style bulb?
can anyone confirm that its just one bulb?
thanks
Old Jul 23, 2009 | 10:47 PM
tw8715's Avatar
tw8715
anyone??
Old Jul 25, 2009 | 10:04 PM
tw8715's Avatar
tw8715
bump
Old Jul 26, 2009 | 12:27 PM
usmanasif's Avatar
usmanasif
What exactly are you trying to get confirmation of? That 168/194 is a wedge-type bulb? Yes it is. If you waited 2 days to get that info when a quick search on Google would've shown you a million pictures of 168/194 bulbs, I feel for you. If you're trying to get confirmation on the number of LEDs in a bulb you found, no one here is gonna have clue as we haven't seen it.
Old Jul 26, 2009 | 12:42 PM
Darkpath's Avatar
Darkpath
From Autoillumination.com the 194 LED crosses to the OEM 168 spade BULB... The 198 is a tower array with LEDs around the tower and one on the very tip... Choose super white that look pretty BA installed... you need to buy TWO since you have TWO Headlights and both have running lights in them.
But use care when installing them because like the OEM bulbs these LEDs are spade type units that merely push into the socket - they do not lock in... and they are a touch longer than the original bulb - If they come out of the socket during install - they could drop down inside your headlight housing which will require removal to get it back out.
Old Jul 27, 2009 | 09:29 AM
1001's Avatar
1001
i have the PIAA LED wedge bulb in mine for over a year now. it fits perfect and they last really long.
Old Jul 28, 2009 | 10:35 AM
tw8715's Avatar
tw8715
before in the 04 headlights i got the LED's off this site
http://store.ijdmtoy.com/JDM-W5W-158...Bulbs-s/35.htm
REALLY good ones.. never burn out.
which one should i pick from theses.
they all are the 168 but many different styles.
thanks
Old Jul 31, 2009 | 11:19 PM
tw8715's Avatar
tw8715
bump one more time to make sure
in the picture. the circle portion..
this bulb size is 168 wedge style?
and there is another small yellowish bulb towards the bottom, is that 168 aswell?
thanks!
Old Aug 1, 2009 | 05:49 AM
tw8715's Avatar
tw8715
also my turn signal bulb is on all the time!
i want it off lol
i heard you can cut a wire on the bulb?
https://my350z.com/forum/attachments...-06-06bulb.jpg
but how do i know which is the front of the bulb?
are all the bulbs have writtin on the front like in the pics?
cause i got some invisible chrome looking ones that i want to put in.
just not sure if its the same for these bulbs too.
how are you suppose to cut the wire?
do i need to electric tape them off after cutting?
Old Aug 3, 2009 | 02:05 AM
tw8715's Avatar
tw8715
bump!
figured out the turn signal being on all the time.
just need to find out what the bulb size and style is for the circled part in the picture.
thanks
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
